Water in Fuel Tank
Water in Fuel Tank
Over the weekend my 1970 LS 5 started normally, ran for about 2 minutes and slowly died.
To make a long and painful story short, I eventually discovered water in the tank. The water level had covered about 3/4 of the inlet sock. After siphoning the water from the tank and pumping out the fuel line, the engine started and ran. I siphoned out almost 3 gallons of gas/water.
I am now trying to determine the source of the water. I last filled up about a month ago and drove the car many times with no problems. It did sit for about 10 days before I tried to drive it on Saturday.
Could the water have been in the fuel at the gas station? If so,wouldn't the problem revealed itself much sooner? Is it possible for that much condensation to accumulate in such a short period of time? While vandalism is always a possibility, I have no reason to believe that is the case at this point.
Thanks.
Thanks.
it might take time for the water to drop down to the bottom of the tank.
You also don't mention if during that 10 day period it sat outside and could have been rained on?
The gas tank neck has a cork gasket where it connects to the tank and it is possible for water to enter if the cork has deteriorated.
If you picked up water at the gas station you would have known it within about 2 minutes of running so I doubt you picked it up there. Some kid may be fooling with your car so you may need to keep a watchful eye on it in the future.
Ok, water fuel mix coming from fuel hose water will settle real quik.start run like crap almost immediately. That much condensation is not possible in a rain forest. That much water can only be rain.
Mel,
Yes, the car was parked outside and it did rain. But is is under a cover. Doesn't the rubber boot below the cap which drains to the rear of the car protect the neck/tank connection? If not, then I will have some more work to do. Thanks for your reply.
Gene
Gene
Received 2,878 Likes
Hi Gene,
I believe the purpose of the rubber boot IS to drain water/spilled gas from the vicinity of the filler neck.
Perhaps begin by checking that the connection from the boot to the drain hose is open and also that the length of the hose is open. There should be a coiled spring in the lower end of the hose to keep it from collapsing.
I'd also check the seal being made by the gas cap gasket.
Regards,
Alan
Regards,
Alan
Alan,
I did check the hose and it did have a minor blockage at the boot which I cleared. The gasket on the fuel cap is deteriorated and will be replaced. I ordered a filler neck gasket just as insurance.
Thank you to Alan and everyone for your help with this one.
Gene
Gene
Hi Gene,
Regards,
Alan
Regards,
Alan
