Stock Throttle Cable Routing?
Old Oct 31, 2015 | 06:54 AM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
Default Stock Throttle Cable Routing?
'71 350/270.
Should my throttle cable be routed on the inside or outside of the left tower that supports the chrome distributor cover?
Old Oct 31, 2015 | 07:28 AM
Alan 71's Avatar
Alan 71
Hi drs,
I'm not sure that it matters.
Mine was originally inside the shielding support. In fact the engine vibration caused the edge of the support to wear a little groove in the cable's plastic sheathing.
I now have it run outside of the support.
So I'd say which ever way causes the least 'bend' in the cable's route to the firewall.
Regards,
Alan
Old Oct 31, 2015 | 07:43 AM
Two Red Vettes
Alan, to the rescue, once again (and with an illustration, no less!).
Thank you.
To Stock Throttle Cable Routing?
