[PICS] Lowered the '68 with a low arch spring
Just got my Van Steel low arch spring today and already installed it.. Drivers side is perfect but passenger side still sits a little high.. Much better than before though.. Might get a 1 inch longer bolt for the passenger side.. Passenger side tire also sticks out a little.. Shouldn't be a problem to fix those little issues..
Nam Labrat
Received 4,173 Likes
Great car and pics!
Is it just me......or should the battery be in a compartment on the Passenger's side...............
my project sits higher by 3/4" on the passenger's side even after rotating shorter leafs 180* and replacing the main leaf that was sagging on the driver's side)
7t9l82 (11-18-2015)
Great car and pics!
It is not uncommon that the body does not sit perfectly straight on the body and there could be also issues with the body mounts..
Great car and pics!
Got the tile for my little garage project there..
I already ordered a set of 9 inch C4 spring bolts. They should work fine and with 18" wheels, there is no risk of them hitting the ground if a tire is deflated..
AirborneSilva (11-19-2015)
Great looking Vette. I like that paint job and the black wheels.
You could come down a few more inches in back.
My official measurement is 2 fingers width between the fender lip and the tire.
Cover up those windows on the garage door to hide that jewel from undesirables...
I will be able to lower it 1 more inch on each side with the longer bolts that I ordered.. Don't want to go 10".. 1 more inch lower should work out fine. I'm not too worried about the undesirables... I have cameras all over my property, a driveway gate and a wall and in case that someone jumps the wall, I have thousands of rounds of ammo and several guns to take care of them... In the worst case that I"m not home, I have good insurance on the car...
Sound like a Texan...
Dr. Detroit
Received 3,892 Likes
Nice stance....that is weird about the right rear....but i am sure you will get it sorted.
You could drop a bob from a point on the frame in the rear up high to the floor on both sides, measure the length and that would tell you if it was at the frame or body......just a thought.
Jebby
Jebby
Jebby
Jebby
