SBC One Piece Rear Main leak or remnants of oil pan leak.
Old 12-06-2015, 04:36 PM
BEVO76
BEVO76's Avatar
Default SBC One Piece Rear Main leak or remnants of oil pan leak.
I spent this weekend redoing the oil pan gasket which was leaking from the rear, and was slinging oil everywhere between the oil pan and the trans pan. This was do to the gasket getting pushed out from a crankcase pressure issue that I had. The pan has sealed and is dry as a bone. However, i am getting a drip on the bottom of the rear main cover. I have new oil in the engine so it should be very clean. The drip that I am seeing is dirty and black. My question is this a rear main leak or left over reminants from my previous leak?
Pics to follow
Old 12-06-2015, 04:38 PM
BEVO76
BEVO76's Avatar
Leak prior to changing the oil pan gasket. You can see where the gasket has bulged/been pushed out.
Old 12-06-2015, 04:41 PM
BEVO76
BEVO76's Avatar
This is what it looked like right after I finished changing the oil pan gasket. Dry and surgically clean.
Old 12-06-2015, 04:43 PM
BEVO76
BEVO76's Avatar
Here is the dirty oil drip after running the engine for 15 minutes. Notice that the oil is very dirty and not clean after changing the oil.
Old 12-06-2015, 04:45 PM
BEVO76
BEVO76's Avatar
Bottom line is this a 1 piece rear main leak?
Old 12-06-2015, 05:17 PM
BEVO76
BEVO76's Avatar
If this is a rear main leak it would be a great oppertunity to pull the old th350 and replace with a beefed up TCI 350 or 400. Seeing I will need to drop the trans to get at the rear main.
7t9l82 (12-07-2015)
Old 12-06-2015, 08:35 PM
BEVO76
BEVO76's Avatar
Went and looked at it again from my view its a rear main leak.....this is awesome. Screw it new trans on the way might as well upgrade if im going in there.
Cant believe I didnt get any feedback from you guys! Normally yall are pretty good....oh well. Happy Holidays!
Old 12-06-2015, 10:02 PM
htown81vette
htown81vette's Avatar
It does look like a rear main seal leak. just my .02
Old 12-06-2015, 10:45 PM
BEVO76
BEVO76's Avatar
Yep thats what I figured. Dry as a bone when not running. A very small spec of oil at idle, and the big drips show up when reving the engine or under load....all the signs are there.
Any recomendations on a beefed up th350? Will I notice a difference between a TCI Streetfighter and a a stock th350?
Old 12-06-2015, 10:59 PM
Peterbuilt
Peterbuilt's Avatar
Received 1,246 Likes on 966 Posts
If your rear main seal is two piece it's easy to change, have you checked what you have?
Old 12-06-2015, 11:01 PM
htown81vette
He said it was 1-piece.
*Edit* - from the looks of it, it has a 1-piece design, I can see the seal housing.
Old 12-06-2015, 11:05 PM
htown81vette
I would avoid TCI but that is just me. Call Circle-D here in Houston, they are excellent.
Old 12-07-2015, 12:51 AM
BEVO76
BEVO76's Avatar
It is a one piece.
Circle-D I will check them out.....going to do it in the spring.
Old 12-07-2015, 02:02 PM
htown81vette
It is a one piece.
They will treat you right. AND they won't make you spend money you don't need to spend, they are very honest.
Old 12-07-2015, 06:58 PM
BEVO76
BEVO76's Avatar
Taking the vette to a shop on 01FEB, I got a great deal on a trans rebuild that I just cannot pass up. I am going to have it built to handle the 500hp thats in front of it with a stage 2 shift kit. While they are in there they can tackle the rear main as well. Stoked about the trans rebuild, guess this was the old girls way of saying hey we need a tranny upgrade.
Old 12-07-2015, 08:49 PM
htown81vette
There ya go!
They'll whisper in our ear, if we choose not to listen the next one will be whap upside our head! LOL.
Old 12-07-2015, 08:53 PM
7t9l82
7t9l82's Avatar
Tranny upgrade,what's Bruce jenner got to do with it?
To SBC One Piece Rear Main leak or remnants of oil pan leak.
Old 12-07-2015, 09:03 PM
htown81vette
Old 12-07-2015, 09:35 PM
BEVO76
BEVO76's Avatar
Oh now thats funny haha. Been a while hope all is well.
Old 12-07-2015, 09:37 PM
BEVO76
BEVO76's Avatar
There ya go!
Lol I like it. She also whispers about a new suspension from time to time. Like an old girlfriend never happy.
Quick Reply: SBC One Piece Rear Main leak or remnants of oil pan leak.
