Need help! Posi unit is stuck.
When properly set up with a .005" side bearing preload it does take some effort to pull the differential case out. It can be pried out using a length of pipe or other pry bar.
This is how I did it.
How far did you install the axle bearings?
Did you reuse the cast iron side shims or did you use super shims?
Did you use the caps to finish pulling the carrier in?
Tim has the best idea. Use a prybar on one of the ring gear bolts at the 12 o'clock position. Use the case as the pivot point. Hold the pinion to keep it from rotating. Once it starts to move, rotate the pinion to re-position the ring gear bolt back to the 12 o'clock position. This will work only so far, until the r&p no longer make contact. From there the stub axle bores should out exposed enough to walk the carrier out.
Once the carrier is out look at the side bearing races for damage from the edges of the rollers. One or both of the races had to go in at an angle for the carrier to be this tight.
The stub axle bearings MUST be installed with the carrier out in order to set the depth. If you install the bearings at the depth of the seal step, or deeper, they will protrude into the case and prevent the side shims from sliding out with the carrier.
Mike
Mike
Mike
The bearings should be flush, or just shy of, the inside of the case.
flyguy767
