Wierd Brake Leak
Old Dec 31, 2015 | 09:14 AM
Cavu2u's Avatar
Cavu2u
Default Wierd Brake Leak
I have an intermittent Right Rear at-the-wheel brake fluid leak. The occasional leak comes down from it's Dust Shield, onto the Wheel Rim's edge, then onto the tire. A lowered rear compartment of the Master Brake Cylinder confirms that the leak is Brake Fluid.
It's weird. The outer and inner (as far as I can see it) Caliper is dry, as well as the Brake Line Fitting to the Caliper. And it's DRY now, and undetectable. Leaks about half a Reservoir compartment's worth of fluid in a 6 month period of almost every day driving.
I suppose I'll pull off the caliper and take a closer look. But just wondering if anyone else here had such an experience, and what they found to be the cause.
Thanks in advance.
Steve
Old Dec 31, 2015 | 11:28 AM
MelWff's Avatar
MelWff
did you push the pistons in and take a close look at the dust boots on each piston?
Old Dec 31, 2015 | 11:34 AM
Cavu2u's Avatar
Cavu2u
I did reassemble them a few years ago. I guess it could be a bad seal in one of the inner Caliper Pistons. Why won't it leak constantly though? Perhaps after I remove the Caliper, it will become evident.
Thanks.
Steve
Old Jan 1, 2016 | 05:51 AM
Danish Shark's Avatar
Danish Shark
I've had calipers leak intermittently, it happens.
To Wierd Brake Leak
