Mufflers Whats Inside
I am re configuring a set of Z06 titanium mufflers to work on my 69.
Converting them to the offset 2 1/2 inlet and 2 1/2 outlet like on a C3.
I know whats inside the Z06 mufflers but not what I should change it to.
If you have pictures of the inside of a stock or performance muffler I would like to see them.
If you have knowledge of muffler design I would like to discuss how to reconfigure the mufflers and still keep it relatively quiet .
One of the best options for flow and noise reduction would be the original style chambered mufflers that came on your car. I don't know if those are still available, but that's what I had on my '72 and '73 BBs. I was never even tempted to change them out. They flowed extremely well, and they had a reputation for that. Several tests of the day showed power losses with other mufflers. FWIW, glasspacks are pretty much the worst when it comes to noise VS performance.
Our mufflers all use a straight-through design, and still dampen sound as much as a standard muffler, without hindering performance. We'd be happy to help you pick out the correct one for your car!
http://www.summitracing.com/parts/mpe-11366
Just bought a set of 11366's... Can't wait to get them on and hear them!
Those mufflers will be pretty loud, if you want the same sound but less noise then look at the same brand mufflers that are a few inches longer.
At the bottom of this page in the Similar Threads section is a thread entitled
Inside a stock muffler
from the C5 Tech section
It has pictures of the inside of a stock Z06 titanium muffler.
This is what I have.
I want to convert it to an offset 2 ½ inlet 2 ½ outlet suitable for use on a C3.
I have 2 ½ perforated straight titanium tubing to accomplish this.
The question was and still is,
How to connect the inlet and outlet without overly restricting flow and still have a relatively quiet muffler?
Pictures of cut away mufflers and the inside of mufflers is the point.
johnt365
Thanks for the picture.
The inside of a muffler was exactly what this thread was about.
454Luvr
I would like to see the inside of a stock chambered muffler.
Lots of information on making the identical copies, but nothing of how they are configured inside.
Magna Flow
Do all your mufflers have straight though curved perforated pipes?
Please show some cutaway pictures of your products.
johnt365
454Luvr
Magna Flow
Coincidentally, I've just discovered part of my exhaust is rusting through. If I decide to replace the entire thing (and I probably will), I'll be looking for a set of early mufflers. I don't know if this design is still available, but that's where I'll start the hunt.
454Luvr (03-31-2016)
Here's a look inside one of our 50 Series Delta Flow mufflers. We use kit-only versions of this muffler in both of our Force II systems for 68-69 Corvettes. These Force II systems produce a moderate exterior and mild interior sound level. If you are looking for that classic chambered sound, these Flowmaster kits will get you there.
Magna_Flow (04-08-2016)
Just be aware that what sounds good at idle and low speed can also be really annoying at highway speeds. At speed, the constant drone of a resonant frequency (from a poorly baffled muffler) can get tiresome very quickly.
If you do much highway driving with your C3, make sure you know how a specific muffler will sound at speed before you purchase.
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've got Pypes RacePros on my 555" and really like them. Noise at low speed is cool...but they do get pretty loud when you stuff your foot in them.
I do admit to liking Flowmaster 2 chamber sounds. I've used a bunch of them. A buddy has them on a pretty nasty 388" engine in his '65 and it sounds 10 times better than mine does at idle and low speed.
You can spot the Flowmaster sound from 3 blocks away!
Years ago I opened up the OEM mufflers on my '88 5.0 Mustang. They were actually very decent designed inside with low restriction. Of course I gutted them anyway and reinstalled them as part of my "stock sleeper" approach to winning a few races to help make the payments! Later I stuck on Flow's because of the sound. (Still got them on the car today!).
JIM
JIM
Ron@Flowmaster (04-08-2016)
I had the stainless Flowmaster 50's on my Vette before I put the side pipes on. They were a tight fit with the longer case size but did not have the drone the 40's are known for. They are currently on my Father-in-Law's 1970 Charger and they still sound great.
Best sounding, worst flowing mufflers ever....
I do like them, and recently bought a set of Delta 40s for my dad's mild 358" SBC, they sound great on just about anything, but I wouldn't run them on anything that's making over 350-400hp....They just don't flow well...
A buddy of mine has a 78' Malibu with a mild/oldschool 468", 3" exhaust with x pipe to 2 chamber Flowmasters (the black/square ones like the original style from the early 90s), 3" tail pipes over the axles. He has QTP cut outs on it as well right before the muffs. On the chassis dyno, he gains 27 rwhp with the cut outs open... A-B-A test style, and this is only on a 350 rwhp car....
Now the Flowmaster shootout mufflers, that's another story...
On most cruiser type cars, 2 chamber Flows are great...
