Who Has Borgeson + Offset A-arm Shafts?
Borgeson recommends some different front end alignment specs after the install. I'm wondering how many of you HAD to put the offset A-arm shafts on after the Borgeson install to achieve the recommended specs?
I like them. I got the extra caster I was looking for. I really like global west products. They are well built and look good. I also got the extended travel lower control arms for coilovers but the shocks and springs are on back order so they are not on yet. Also have their rear trailing arms.
What size wheels and tires are you running in the rear with those offset control arms? I just purchased a set and haven't got them installed yet. I was hoping to get a 10" wheel on but I don't know what backspace to use. Thanks for your input.
I've got the Speed Direct aluminum upper control arms - good for 6* pos. castor setting. Have mine set to 4.5* pos. castor and the steering is now exceptional. No more being pulled around by uneven pavement. On a good road she tracks in a straight line with my hands off the wheel.
Here's a couple of pics on how they fit:
Speed Direct upper control arm and Borgeson power steering box
Steering box close to header but no touch - can easily remove and replace header.
Who makes those headers? are they for side pipes? What part #
Colesweat, they are sidepipe headers. But the unfortunate thing is they were built for my '65 by a header guy here where I live. And yes they are built very well. With polished ceramic coating they cost me $1500.00 - not cheap but they are a perfect fit.
Custom built headers with ceramic coating
65-StingRay
65-StingRay
Sacred Steel, what coil overs are you going to use with the Global West arms. I was looking at those arms and they look great. Like the idea of the extended travel lower. Thanks,
Bill
Bill
The control arm # is CTA-31EXT.
Thanks for the numbers. Did you buy direct from Global West or from Jegs or another vendor? That Global West stuff looks so strong, but you are the first here I have seen using their stuff.
Bill
Bill
I bought this particular set up directly from global west because I don't think summit carries them yet. I generally buy from summit for the free shipping but had no choice on this one. Their stuff looks nice on the website but once you hold one in your hand, you can see and feel how well built they are.
http://trzmotorsports.com/wp2/?produ...ms-coil-over-8
I went with TRZ .. Have had them on for a season and there perfect .
I just ordered the Moog off-set control arm shafts , will see how much positive camber I can get.
http://shop.advanceautoparts.com/p/m...ontent=general
