Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Reload this Page >
Best A/F ratio and timing for low rpm cruse with big cam and CI engines
Old 04-07-2016, 02:42 PM
69427's Avatar
Location: I tend to be leery of any guy who doesn't own either a chainsaw or a handgun.
Liked 189 Times in 161 Posts
Originally Posted by zwede View Post
But he has EFI so he doesn't have the limitations a mech/vacuum distributor has. I've had very good luck with lots of advance at very low load. At WOT I don't max out until 3000+ rpm, yet I run over 40 dgrs at 1500 rpm low load.
As cuisinartvette mentioned earlier, just give the engine what it wants.
69427 is offline
Old 04-07-2016, 03:56 PM
pauldana
CF Senior Member
Support Corvetteforum!
pauldana's Avatar
Liked 278 Times in 223 Posts
Originally Posted by diehrd View Post
So your saying it idles fine at 850 , but if you try to slowly move the car it gets choppy or wants to stall ?
yes
thx
pauldana is offline
Old 04-07-2016, 04:03 PM
Neil B
CF Senior Member
Liked 103 Times in 81 Posts
Here's my combo:
372ci small block
13.5:1 compression
268/[email protected] 108 ls solid roller
AED 950 Holley
1,400rpm idle
7.5" vacuum
26 degrees initial timing with custom 10 degree advance stop bushing
14.4-14.7:1 idle afr
12.0-12.5:1 cruise afr might go to 13:1 under very light load)
11.5:1 WOT afr
That is with stock AED air bleed calibration and drives pretty nice for an 8,000rpm race engine. I'd like it to be a bit leaner under load.
Neil B is offline
Old 04-07-2016, 04:42 PM
gkull
CF Senior Member
gkull's Avatar
Liked 353 Times in 320 Posts
Higher compression atomizes fuel better. atomized fuel burns faster. Combine that with modern fastburn heads like in Paul's case AFR 227 cc with small mid 60 cc chambers and being Heart shaped are not a good comparison to BBC large chambers.
If anything highly atomized fuel droplets like out of a 8 port injection system would require even less timing that it's carburated counterpart
gkull is offline
Old 04-07-2016, 05:09 PM
zwede
CF Senior Member
zwede's Avatar
Liked 201 Times in 179 Posts
OEMs do the same thing. I checked the timing map on my Gen II LT-1 (port injected). Even with the tiny OEM cam (206 dgr duration) GM gave it over 40 dgrs advance at 1500 rpm at low load. Mech/vacuum distributors are so off ideal advance it's a wonder they run at all.
zwede is offline
Old 04-08-2016, 09:25 AM
gkull
CF Senior Member
gkull's Avatar
You can't even compare the two. The timing on a modern computer ignition car is fluctuating 100 times per second always trying to give max advance until it senses knock.
I had a laptop hooked up and the timing numbers are just a blur. So your 40 degrees might have been for only one cylinder and then ping and it dropped right back down. I have never seen a constant advance number on distributor less ignitions.
As for me I have rebuilt enough HP motors and looked at the bearings to know that stupidly fast advance curves just hammer the barrings.
I'm also not a fan of aftermarket FI systems. My friends find these super dynotune places and they cost about $600 for 4 hours of tune time to get their aftermarket systems running the best possible. They don't have 100's of millions of dollars to perfect them like the car manufacturers have.
gkull is offline
Old 04-08-2016, 09:53 AM
zwede
CF Senior Member
zwede's Avatar
You can't even compare the two. The timing on a modern computer ignition car is fluctuating 100 times per second always trying to give max advance until it senses preignition.
I don't really feel like arguing, but I've never seen an OEM system intentionally running timing into ping. They have a timing table set for the octane the engine is speced for. If it senses pinging it does a pretty big retard, then slowly advances back to zero retard unless it senses more pinging.
Also, pre-ignition is different from pinging and will destroy an engine in seconds.
OP wanted to know how to optimize low speed drivability. Lots of timing advance is the answer. Even if he goes too far, some pinging at low load isn't going to hurt anything.
zwede is offline
Old 04-08-2016, 01:37 PM
69427's Avatar
You're batting a thousand in this thread. Keep up the good work.
69427 is offline
The following users liked this post: 69427
zwede (04-08-2016)
Quick Reply: Best A/F ratio and timing for low rpm cruse with big cam and CI engines
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
