Headlight vacuum actuator
I think my vacuum pods are on the wrong side. I've never taken them off and never really even looked at them. Headlights go up and down just fine but I just noticed the vacuum tube are doing a 180 degree bend when I took the hood off.
<br >
<br >
<br >
<br >
Received 2,878 Likes
Hi D,
I believe you'll find that original and reproduction hoses are perhaps a little longer and have 90 degree bends formed in the end at the accuators.
Regards,
Alan
Regards,
Alan
Since they work fine, I would suggest that you NEED to leave them alone. The mounting studs on those cans cannot withstand much force when removing the nuts; and it is a REAL PITA if you snap one or more off [of rusted nuts/studs] during disassembly. You can repair them, but not fun. And replacement is expensive.
Just be happy that they are doing the job without problems!
mrvette (04-08-2016)
Hi drw,
46000 miles on the odometer…. all with me behind the wheel.
Regards,
Alan
Regards,
Alan
Dr. Detroit
Received 3,892 Likes
If I were you I would buy a bunch of hose and swap out all of the lines.....you can route yourself a much more gradual sweep to the can...that old hose is about collapsed.
Canisters run about $80 a piece......the vacuum relays about $50 each.....I do not recommend the cheap relays....some leak right out of the box.
Remember....a leaky headlight/wiper system can affect engine performance.
I replumbed the 76' in about 45 minutes with $20 worth of Vacuum hose and some zip ties.
Jebby
Dementer sole survivor
Received 6,278 Likes
2016 C3 of Year Finalist
I'm still jealous of your car though
Hi RR,
I twisted those words to seem to say something they REALLY don't.
Since I'm the original owner I've driven it those miles years ago…. 35,000 in the first year and a half…. another 10,000 in the next 20 years and only a couple of hundred more since!
I don't drive it anymore!
Regards,
Alan
Regards,
Alan
Hi RR,
Regards,
Alan
Regards,
Alan
