6 speed : cheapest option?
for a standard small block, besides the t56 what (if any) other options are out there for a swap?
I'm not building a monster engine, so a standard tranny that was in any passenger vehicle should hold up just fine.
If you on the lookout for some cheap then there is nothing cheaper than an used T56 given it's in good shape and/or you do the overhault yourself.
Want even cheaper? Go 5 speeds with a T5.
Does such a thing exist?
T56. I got one from a '96 LT1 for $1200. Included bell housing and hydraulics, cheap shifter. I needed the adapter flywheel, not cheap so include everything in with your estimate. I have read that the T56 I have with the .5 second overdrive is good to 450 lb./ft.
here are some T56 and T5 ratios
http://www.tacreationsusa.com/manual_trans.htm
