73 seatbelt warning light and buzzer won't go out?
Just got a set of rebuilt original lap belts for my 73 convertible. Connected everything turned on the key and the dash light came on and the buzzer came on, but when I pulled on the belts they didn't go out??.? On the 73 you only need to pull up on the belt about 10 inches or so and everything should go out. If I pull up on the e- brake one click everything goes out. Is it a relay or wiring problem? Hope the belt switches aren't bad. These came from Charlie at seatbelt city?
Let me know what you guys think!
Thanks,
Jim
Thanks,
Jim
If you didnt have the problem before the belts were done, call Charlie.
That's the problem. The original belts were removed by a previous owner back in 1992 and replaced with aftermarket belts with no wiring. The seatbelt warning system hasn't functioned since before then. So I don't know where to trouble shoot first.
Thanks.
Thanks.
Received 1,244 Likes
This is the only 73 seat belt diagram that I could find and it's useless since I can't read it!
http://www.vetteprojects.com/bmv/mis...tte%201973.pdf
Any chance that you have a better diagram in your 73 service manual that you could post so someone can figure out what the problem is?
Tooch
251563109391. Worth a try?
Tooch
