oil pressure issue
Old Apr 17, 2016 | 05:42 PM
blue427's Avatar
blue427
Default oil pressure issue
My 69(427)usually has an oil pressure of 34lbs at idle(900rpm)when warm(15-40 wt oil)and around 50lbs at3000rpm with a stock oil pump.Today it would only go to 36(or so)lbs at cruising speed(3000rpm).When I came to a stop it went down to about 26lbs,then drove a little further and she stayed at 34lbs when I stopped.The engine is pretty fresh with maybe 4 or 5000 miles so I'm pretty sure it's not the bearings.I've just changed the oil and filter(K&N) and wondering if this could be a bad filter,I've never had a bad filter so I don't know if it could cause this type of problem.The other thing that comes to mind is a failing oil pump,the pump is older as the one that was put in at the time of the rebuild read very low so I put the old one back on(maybe 20 or25000 miles on it.I would appreciate any insight or suggestions.Thank you
Old Apr 17, 2016 | 05:58 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Verify first that the gauge is correct. All it takes is a little dust on the gauge gear to impact the functionality. Pull the gauge, clean the mechanical gear, test it with some shop air.
Old Apr 17, 2016 | 06:01 PM
CanadaGrant's Avatar
CanadaGrant
A problem I had with my 69 L36 was that the oil pressure gauge was slow to respond and registered low at times. I removed the line from the back of the gauge and the fitting above the filter and blew the line out with compressed air at the gauge fitting. That cleared it up but it could also be a sticking gauge. I would look into both before considering a motor or oil pump problem as you said the pressure came back up.
Old Apr 17, 2016 | 06:23 PM
blue427's Avatar
blue427
thanks from both of you,will do,Mike
Old Apr 19, 2016 | 12:12 PM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Had issue like that awhile ago, turned out i was quart low, hope you get it figured out.
Thanks again fir help few weeks ago.
If you were on way to Captree when oil issue popped up, all lots were full all way to water.
Cars lined up past entrance pulling in.
Greg
Old Apr 19, 2016 | 06:36 PM
blue427's Avatar
blue427
hi greg,I left before you got there,problem only started on way home.I'm hoping to get it squared away before the weekend.My oil is full just changed it,Mike
Old Apr 19, 2016 | 09:59 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Could be a clogged oil line to the gauge. Another thread here reported that issue. Has the outide air temp changed dramaticlly or is the car running hotter. Either could thin the oil if your just used to the cold temps of the winter
Old Apr 20, 2016 | 03:04 AM
7T1vette's Avatar
7T1vette
First thing I would do is change the filter to see if the oil psi changes. That would be an easy and cheap test...and you lose nothing in the process. If nothing changes, you can still use the other filter later. That will eliminate the filter as the 'problem'; but you still have the problem. (It would be best to stick another psi gauge in the system when you change the filter out. You will be testing two things, but the extra gauge keeps the testing 'clean', as you can use the dash gauge to evaluate change due to filter swap.)
It could also be that the K&N filter you installed has better filtering capabilities, but causes more resistance to oil flow (because of finer filter path) and it drops more pressure across it. To assess this issue, you should replace your present filter with an exact duplicate filter (K&N).
If the psi goes back up with filter swap, the filter you have now is junk (likely leaking overpressure dump). Take it back for a refund or pitch it.
Old Apr 20, 2016 | 04:00 AM
Mountainoakie's Avatar
Mountainoakie
If the oil filter was plugged solid you would still have full oil pressure because the filter bypass valve would open. I still suspect the nylon tubing going to the gauge has a kink in it because mine did the exact same thing several weeks ago. By pulling the gauges foreword and re-positioning the line my gauge read normal again.
Old Apr 20, 2016 | 07:09 PM
blue427's Avatar
blue427
7T1vette is the winner.I changed the K&N and put on an AC filter and all seems to be good.I've used K& N before and never had any issues.I probably ditched the receipt so there goes $13 down the tubes,but on the bright side,a cheap and easy fix.Thank you for all the good responses,I'm sure I'll probably be needing them in the future. Mike
To oil pressure issue
