Ok let's play name that wire .. Again
Received 1,469 Likes
Cruise-In II Veteran
Let's play "what are you calling a windshield actuator" and then we'll play model year.
I think you mean wiper door and that would get you 68-72. Your green may be the connector for the wiper detent switch.
Received 2,878 Likes
Hi f,
I believe the long pigtail for the temperature sensor in the right side head connects to the harness at that point.
The pigtail has the additional length because it's a resistance wire so shouldn't be cut or shortened.
Regards,
Alan
Regards,
Alan
The temperature sensor, to operate the temperature guage, is on the driver side. On the passenger side is a temperature operated switch which is a part of the Transmission Controlled Spark system. This system was usually disabled and or eliminated by most owners.
Gene
Gene
