PSCV replacement 1969
So one last question for today, i am about to replace the power steering control valve and ram. I have a new unit ready to go with some heavy duty jack stands. I found an excellent video of the change out on You Tube, but, I understand the cars wheels have to hang freely and the car started to calibrate the PSCV, so
Where do I safely put my jacks. I did lots of reading and looked under the car but can't find a good place to put them knowing I will have to run the car to set the PSCV.
I searched the forum but couldn't find a good reference.
Thanks for any advice.
Pete
Pete
Pete
Pete
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
I remove my wheel to get better access to the adjusting nut. Place your jackstands on the side frame rails in the area a few inches forward of the front door seam. The frame rails actually curve slightly upwards just forward of this point so you must make sure your jacks are not positioned there. Poke your head under there to make sure you have them in the right spot.
Thank you so much, I will put some safety blocks there instead and have the jack stands as you say.
Pete
but I did get the car safely on jack stands and removed all the hoses with no issues. I now try to disconnect the PSCV from the pitman arm but I just can't remove it.
I have tried and tried, why is it so damn tight, shouldn't it just slide off the top? I have a pickle fork which is says NOT TO USE in the instructions.
Any ideas, do I need some type of puller instead or shall I just bang on it harder!
Thanks, Pete
why wouldn't you use the pickle fork on the old valve? The fork with a few taps with a large hammer and the valve comes off.
I have no idea why they say not to use it in the instructions, maybe they want to keep the old one in good shape.. I don't care, I have a new one waiting on the bench!
I have never done this job before, here it goes!!
I could't get mine with a pickle i used a pitman arm puller i borrowed from part store gave it a whack snd bingo.
Thanks for all the help!
Here is the you tube link to the change out. Hardest part was getting both wheels off the ground, after that it was easy but definitely remove the front drivers wheel for easy access.
I bought mine at Lordco which is in British Columbia only but equivalent to a Napa or Auto zone. I believe the same ram cylinder and PSCV is used from about 1963 to 1978 and likely on many cars other than the corvette so they are easy to find.
Wilcox or Corvette Central have them for about 100 each rebuilt plus core charge.
Wilcox also has a great video on rebuilding the PSCV if you feel like saving a few bucks. I would have but have just too many things to do on my car and just didn't have the time.
It is about a 4-6 hour job for me and probably less for someone who has any idea of what they are doing.
Best of luck
Pete
My New PSCV and RAM in place
Best of luck
Pete
