Metal floor added to fiberglass one in 1975
There are aftermarket metal floor pans made the only problem you'd have is your trans tunnel and frame rail sides are fiberglass so you'd either have to graft the metal floor pans to the fiberglass or while your body is out make a new trans tunnel and side rails to allow you to weld the floor pans in.
I think you are overthinking this as thousands of C3's were made with fiberglass floor pans and I've never heard of something coming through one.
75 c3 ,,,, rotted metal under seat
drivers side - when I went to move the seat up to get to the back bolts the whole damn seat came out with the ****,,, it's all rotted & someone held it together with ductape!!!
Question- can I purchase prefabbed floor board's???
Also, passenger side bolts are different sizes & all rusted and rounded out, any tips on how to remove w/o messing up the carpet which actually is in good condition,,,
lipstick on a pig I guess!!! Someone hacked this together!!! Thanks for your input!!!
Good evening, I am in the process of redoing the seats,
Thank you for your reply!!!
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
