Non-Fugly C3 Hood Insulation?
Old 07-30-2016, 09:21 AM
REELAV8R
REELAV8R's Avatar
Received 1,033 Likes on 852 Posts
Originally Posted by NewbVetteGuy
Hmm... Yea, you're probably right. Ensolite sells a glue-on version. Do you think something like the 3M adhesive would work better?
Adam
The 3M glue is god stuff. But it doesn't work for headliners over time due to the heat that can build up under the roof of a car, so I would say no, it probably won't work in the long term either.
I'm sure there is a glue that can tolerate the high heat situation under the hood. Certainly a gasketing type of silicone glue would tolerate the heat, but may a be a pain to apply to a large area. Mechanically attaching it may be the best way to go if the product you use is somewhat rigid.
Quick Reply: Non-Fugly C3 Hood Insulation?
