Diff Side Yoke moves in and out ALOT
Well I took your advice and pulled the diff out today, passengers side YOKE can be pulled out of the housing
I will get it all cleaned up and pull off the cover and see if the clip has just come off and still inside or been ground up.
Andy
Andy
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,924 Likes
With any luck, the rebuilder forgot to install the snap ring and everything is just fine... With bad luck, you have a completely chewed up stub shaft and a lot of metal debris... Here's wishing you the former.
Pulled the cover off the diff and found a half round piece of metal very thin and made from stainless steel.
Its about 37mm across
Does not look like a clip to hold in the Yoke, any ideas ?
Found it stuck in one of the clutch springs !
https://www.corvetteforum.com/forums...1&d=1470456039
Found the Yoke clip, it was down the bottom in the cavity under the gear.
now need to work out what the other piece is from and were.
https://www.corvetteforum.com/forums...1&d=1470460267
You can see the snapring installed here:
Lars found the snap ring a the bottom of the housing as in the previous post and still in one piece.
The other piece of metal is a Pinion Depth Shim, which has come off after the snap ring came off the yoke
The yoke on the drivers side has two of these pinion Depth Shims in place now. Will get a picture and post soon
I am assuming you can use these to adjust the of slop between the spline and pinion shaft
The drivers side end has mushroomed from wear and want to remove it, whats the best way to grind down the burr on the end ?
Lars
