No headlights when dimming
71 Vette. Lately when driving at night my headlights work normally when going from bright to dim. However after a number of cycles when I hit the dimmer to switch from bright to dim, I have no lights at all. I can then press the dimmer switch back to bright and all four headlights are on. If I park for a while the system goes back to functioning correctly. It seems like something is overheating and causing this condition.Is this likely a dimmer switch problem or something else.
Received 3,220 Likes
Sounds like it could be the dimmer switch...BUT there is also a circuit breaker in the headlight switch and if for some reason you have a bad bulb/wire on the low side the breaker will trip.
At the dimmer switch you have three wires-
Light Blue- power from headlight switch
Light Green- goes to high beams
Tan- goes to low beams
You can connect the light blue wire to the tan wire- and bypass the dimmer. If no issues- then it's the dimmer.
If issues- start by disconnecting one low beam at the time- then you can narrow it down whether a bulb or wiring.
Richard
Richard
gnkjoy (08-05-2016)
If you replace the dimmer, your problems will be history. Check the connector at the dimmer for corrosion while you're there.
