Bright Idea - LED Corvette Lights
Old Aug 5, 2016 | 01:27 PM
joe@zip's Avatar
joe@zip
Platinum Supporting Vendor
Default Bright Idea - LED Corvette Lights
Zip Corvette is your source for LED Corvette lights!
Why switch to LED's? You already know they are energy efficient and eco-friendly. But LED's are also a great way to set your Corvette apart from the crowd and increase safety as you drive. LED lights are brighter, appear quicker and burn cooler than your Corvette's factory light bulbs.
Most LED lights require no modification for installation and you can return your Corvette back to it's factory original appearance at any time.
Zip's inventory includes something for each Corvette generation. From C1 Tail Lamps and Bulb Assemblies to C7 Fuel Rail Lighting Kits, we have the LED Corvette parts that you've been looking for!
Old Aug 5, 2016 | 01:46 PM
keithinspace's Avatar
keithinspace
I had already tried to convert my car to LED's, but ran into the dreaded "not enough load on the blinker thingy so they go really slow" syndrome.
I tried to fix it by using resistors, but wasn't 100% happy with where it left me. The bulbs I had originally purchased didn't 'agree' with the resistors, and the bulbs that worked with them worked poorly in the rear because of how they were configured. They were so dim that I got several "hey, you're brake lights are out" window shouts from fellow motorists.
Then...it happened. I was coming back from Cars and Coffee and I came 2 inches from being rear ended by a blue CRV with an EASY 40 MPH closing speed that didn't see me braking or turning. Obviously, he should have recognized my maneuver even if I had no taillights whatsoever (which I did...they just weren't as bright as they could have been), but it gave me the heebie jeebies about my light situation.
ZIP Corvette to the rescue!!! I got their 'electronic blinker' thingy that is timer based, not load based. So I get a good, solid blink without any resistors and I've been able to swap to my "rear facing" replacement LED bulbs that didn't like the resistor configuration. Taillights are now considerably brighter than even the stock bulbs, but without any of the heat. Which the plastic light covers appreciate.
This configuration is a little different than what Joe is selling above, but yet another example of "whatever your Corvette issue, ZIP can help".
Old Aug 5, 2016 | 05:27 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Most useful review EVER!
Adam
Old Aug 5, 2016 | 07:41 PM
myoriginal77's Avatar
myoriginal77
I may be wrong but I think any auto parts store carries an "electronic" flasher which is not load based, they were about $10 last time I looked. They have been around for years and typically cured fast blinking that was caused by adding trailer lights.
Happy Motoring,
Frank
Old Aug 5, 2016 | 09:24 PM
terry82's Avatar
terry82
replaceing the outside lights are a good idea but,,, I replaced my interior lights, dome and lower courtsy light .wow huge difference .much brighter at night.best mod I have done this year.
Old Aug 6, 2016 | 06:42 AM
LT1M21Vette's Avatar
LT1M21Vette
I did upgrade. Great for your old wiring, as they draw much less current.
www.superbrightleds.com/led-vehicle-replacement-bulbs/
Got everything needed from these guy ^^. Great customer service.
Old Aug 6, 2016 | 08:35 AM
V4motorsports's Avatar
V4motorsports
I talked with Daniel Stern and his recommendations were:
Put these in the brake/tail lights:
Amazon.com: Philips 1157 P21/5W Red X-tremeVision LED Exterior light (Pack of 2): Automotive Amazon.com: Philips 1157 P21/5W Red X-tremeVision LED Exterior light (Pack of 2): Automotive
Put these in the reversing (back-up) lights:
Amazon.com: Philips 1156 P21W White X-tremeVision LED Exterior light (Pack of 2): Automotive Amazon.com: Philips 1156 P21W White X-tremeVision LED Exterior light (Pack of 2): Automotive
You will need to swap in this turn signal flasher:
Amazon.com: Tridon EP37 Flasher: Automotive Amazon.com: Tridon EP37 Flasher: Automotive
(2-prong like original, direct swap)
Also note these recommendations are very specific -- they are the only legitimate LED retrofit bulbs. There's a mountain of garbage on the market, too, so use _only_ these specific LED bulbs.
Can be seen now!
Russ
Old Aug 6, 2016 | 05:10 PM
brybrew's Avatar
brybrew
Just curious but does anyone have pics of the LED replacement bulbs? I would guess this may be hard to see in a picture. I have been thinking about this option (Mainly to decrease the load on the original harness/safety) My lens in my 69 are in good shape and I don't care for the whole lens replacement option looks. the bulb replacement looks interesting.
Old Aug 6, 2016 | 11:16 PM
keithinspace
I'll try and take pics for you, Mr. Brybrew, but your situation is exactly where I was. Perhaps I'd like to someday do the "halo" thing with the blinkers in the middle of the circle, but I have bigger fish to fry. And I wanted to keep the "old" lens covers and the look of a stock light. Wasn't a money thing, just a look thing.
Without the pics, all I can share is that the LED's are a slightly brighter, slightly 'faster' version of the stock bulb. Just without the electrical load. Or the heat...which had done a good job of melting my license plate light into a brown oddly shaped puddle of plastic over the past 46 years.
Old Aug 6, 2016 | 11:38 PM
Richard454's Avatar
Richard454
Here you go- LED replacement bulbs from Superbright- behind OEM lenses
Sequential light module from Speedway motors-
Moved the reverse light....see below
More LED bulbs up front from Superbrite and another sequential module
LED -inside the stock side mirroes-
LED reverse lights-
Old Aug 6, 2016 | 11:59 PM
LT1M21Vette
1157/1156 45 SMD LED replacements from Superbrightleds.
Old Aug 7, 2016 | 09:24 AM
brybrew's Avatar
brybrew
Thanks Guys! Yeah I would like to change my taillights, license plate and marker lights and eventually the others. Looks like I have another weekend project to add to the list.
And Richard, That's one heck of a Reverse Light! I'm sure that will get a few comments when you back into anywhere. Nicely done.
Old Aug 11, 2016 | 10:25 PM
MSGT-R's Avatar
MSGT-R
Happy Motoring,
Frank
Not anymore. I checked Advanced, O'Reilly's and Pep Boys. No more two-pin electronic flashers, only OEM.
Old Aug 12, 2016 | 07:37 AM
keithinspace
Two things:
#1: The blinker thingy from Zips Corvette has a converter on it that makes it a plug-and-play deal for our cars. No thought, contemplation, or adjustment. Get behind the dash and swap it out. Done.
#2: As a continuation to my LED light bulb fetish, I just purchased the absolute brightest (800 lumen) RED bulb I could. Side by side with the white bulb, I have to say the difference is pretty dramatic. With the white bulb, the light is 'colored' by the now-46-year-old lenses that have inherent thin areas and other nuances. With a RED bulb, the taillight emits RED. Not 'red-ish' or 'red-through-46-year-old-lenses'. Just a VERY bright and glorious and ridiculously red light.
I think I'm finally happy with my taillights.
Now I just need to replace all my AMBER light positions with AMBER LED bulbs in lieu of white. Oh...can't forget the headlights. The fetish continues...
Old Aug 13, 2016 | 03:44 PM
MSGT-R's Avatar
MSGT-R
I once did all this to a Honda GL1100 Goldwing Interstate. Not only did it make a dramatic difference, but it also saved on the low-speed charging load of a marginal system design.
Old Aug 13, 2016 | 07:04 PM
LT1M21Vette
Two things:
superbrightleds.com/carbulb_notes
Originally Posted by superbrightleds.com
For best results the LED color should be the same as the lens color or if bulb is behind a clear lens, use the appropriate color for turn and brake light functions. As an example: a red lens will filter out all but the red portion of the light so if the light is all red, none or very little light will be blocked by the lens. The light from a White LED contains very little light in the red portion of the visible spectrum so most of the light would be filtered out by a red lens.
To Bright Idea - LED Corvette Lights
