Horn on my 1981 Vette
I have a 1981 vette and it has tilt and telescoping steering wheel. The only way the horn blows is when you unlock the telescoping and push the steering wheel all the way down. Any thoughts as to what I might look at.
take it apart and look at the horn ring.could be as simple as being dirty or the ring needs replaced.https://www.corvetteforum.com/forums...-easy-fix.html this was a fix I did to mine
It should be fairly obvious when you get into it. The horn button contacts the ring and the horn contact at the top grounds it when you push the cap. It blows when that disk down there is grounded, so just look for what changes when you move the wheel down. It may be the spring loaded horn contact button is corroded or the spring collapsed.
