Vacuum system..
Vacuum system..
Hi guys,
Should be an easy one for anyone experienced with these cars.. How long do you think it would take to install a new system to run the,pop up lights and wiper door in an early c3?
By new, I mean the original system has been ripped out,,and this would be built up from a kit.
Many thanks for thoughts
David
David
I think that is a difficult question to answer, since there are so many variables in these systems. Is your wiper door functional or is it frozen? Just rebuilding this could take a lot of time. You may be able to spray lube into all the rotation points and get it to work instead.Do you need a new wiper door canister? Do you have all the correct components ready to go?
Reaching some of the bolts that hold on the vacuum relays are a bear to get to. Do you have a vacuum system diagram that shows how they are all connected? (these are available online) If you come across stripped holes, that will take extra time to deal with as well.
Are you replacing the vacuum solenoid switch at the back of the tachometer? (that is not fun to get at).
I would guess, if all goes well, you could do this in a day, but we all know that something will always hold us up!
Received 2,878 Likes
Hi David,
Welcome!
New Member!!
And, in Australia!!!
I also agree that although we refer to it as a vacuum system, it's really a mechanical, electrical, and vacuum system…. there are actuators, relays, electrical switches, vacuum/electrical switches, override switches and hoses.
Since both the wiper system and headlight doors are controlled from the dashboard getting things working correctly can sometimes be quite a challenge because of the difficulty of working under the dash.
In addition the actuators, and safety switches have adjustments on them that must be understood in order to have them function correctly in the system.
This results in there being lots to understand about how it works and thus what might be going on when it doesn't.
Certainly many folks are able to get the systems working nicely, but it generally takes MANY hours of work.
If you're going to undertake this pray for patience!
Regards,
Alan
Welcome!
New Member!!
Regards,
Alan
[QUOTE=Kirk H;1592787646]Do you have all the correct components ready to go?
Thanks, very useful!
This is a good question.. Any idea where I can obtain a full component list?
I would suggest testing all your current vacuum components first.
running a new hose kit to failing components only gains you frustration.
determine what is missing, what you need to replace/repair,
a new hose kit is cheap about $100. use this information to determine if its worth it to repair current vacuum system,
or change out to something different / electric.
Hi Dave,
The list:
Vacuum check valve.
Vacuum filter.
Headlight actuators. (2)
Wiper door actuator
Manual over-ride switch. (2)
Relay valve. (3)
Vacuum reservoir tank.
Headlight switch.
Wiper switch.
Wiper door 3 port interlock switch.
Wiper door solenoid valve.
Wiper door limit switch.
Wiper arm control switch.
Hoses and 'T's
The mechanical components that make up the headlight door mechanisms and wiper door mechanism.
Regards,
Alan
The list:
Vacuum check valve.
Vacuum filter.
Wiper door actuator
Relay valve. (3)
Headlight switch.
Wiper switch.
Hoses and 'T's
Regards,
Alan
Received 1,469 Likes
Cruise-In II Veteran
Yep. The AIM shows the installation of all the parts of the vacuum system, the color coding of the hoses, and lists the original GM part numbers.
wiper
Hi Phil,
You say you have "it off". Do you mean the door or the door and it's mechanism?
If the mechanism is still in place, is the grill off?
Is the link completely unhooked from the actuator?
Is the link to the wiper safety switch unhooked?
If you remove the mechanism from the car it's more likely that you can get it to work again since there's less constraint on the ends of the mechanism when it's free.
You may be able to free up each end separately and then work on the links for the actuator and safety switch.
While there certainly a lot of pivot points you can try to work on each one independently.
I would spray each pivot point and then use a soft brass brush to try to clean the accumulated crud that's around the pivot bushings.
Not Easy!
Regards,
Alan
Not Easy!
Regards,
Alan
You mention a frozen wiper door and mine seems frozen I have it off
