C3 Ignition problem
Cruising
C3 Ignition problem
My 1979 L82 has a ZZ4 turn-key crate motor (installed 4 years ago). Had some misfiring problems, so had a new HEI Street Fire distributor put in (2 weeks ago). Car ran amazingly well until it lost alternator power. Now when I charge the battery and try to start car, all power goes out (no lights, power to dash, etc.). Any thoughts? Bad ignition switch? Could the new distributor cause another problem with ignition? Any recommendations on further testing? Thanks for your time!
Sounds like a bad connection at the battery or battery cable somewhere. OR possibly a ground issue. That is assuming the battery is charged enough to start the car. Clean and tighten the terminals and make sure there isn't corrosion where the cable goes into the terminal as well. Good cheap place to start.
mulcaheys (08-17-2016)
Cruising
Found the culprit! It was a break in a corroded wire to alternator. Replace wire and car started like a champ. Alternator properly charging.
Dementer sole survivor
Received 6,278 Likes
2016 C3 of Year Finalist
That wire looks.like it doesnt have any insulation on it. You may want to check and see if it was grounded out and maybe shorted or something
Cruising
Thanks. Yes, there was about 5 inches or so with no insulation. Also was badly corroded. Wasn't really sure if root cause was corrosion or short. It appears that it had been that way for a while. Wire was completely severed, cutting off power from alternator. I inspected the wiring and replaced the entire bad section. Everything seems to be working normally now.
Good job. Congrats on figuring it out
Anyway, please avoid the hell I'm experiencing over something so simple yet devastating. Ensure the wire is clean as you can get it & re-insulate it with heat shrink. Use solder if the wire is stranded if possible.
I would also suggest investing a little time (and knuckles) to follow that wire end to end if possible. That looks like it got extremely hot and the burning is extensive. I suspect there was/is a direct short somewhere and it needs to be found. The one possibility that eliminates a "mysterious" short is if you KNOW that someone accidentally shorted the wires on the alternator during a change / maintenance.
saunderscx (08-20-2016)
Good choice. Better safe than sorry.
After spending a couple of hours looking for this short (which I haven't found), I'm inclined to agree with you. A new forward lighting harness will take the guess work out of the equation. The starter/engine wire harness is beat down & could stand to be replaced as well. Time for a refresh. About $450 for both.
