i look at the toe adjusters in the 1982 trailing arms
to figure on what the alignment shop needs to do....to crack the nut
the po had it rebushed in 2006 and the car is a california car
i don't see the bolt head, can i check to see if it's frozen or not? by pulling the cotter pin and throwing a wrench on it?
and do i need to by the shims or most shops will have them?
need pictures
need pictures
Received 2,878 Likes
Hi s,
"need pictures"
Here are the typical shims/cotter pin, and the t-arm pivot bolts/washers/ nut/cotter pin.
Regards,
Alan
The trailing arm, drilled t-arm bolt, heavy flat washer, slotted nut, cotter pin.
Upper tip of outer shims, long cotter pin.
"need pictures"
Regards,
Alan
slickfx3 (08-28-2016)
i still don't get how the bolt comes out on the other side , if i had to remove the T/A, not that i am going to
btw aren't you suppose to bend that cotter pin?
getting the shop to actually do the work required is the problem, their idea of good enough will likely leave you with no trust angle or toe adjustments in rear. They'll set front caster, camber, toe, & and rear camber and hand you a bill. After several attempts at paying shops to do mine, I bought turn plates, lasers, camber/caster setting tools from Longacre Racing and did my own... I consider it perfect. Took me a full day after leveling car, finding chassis C/L, projecting to floor with plumb bob, creating horizontal offsets from said line, checking trust angles, setting toe front rear, caster, camber front, camber rear, rechecking toe, blah blah blah. Used lasers for front to rear checks. No more pulling, darting in rutted pavement or wasted cash to lazy azz clowns.
jim
jim
slickfx3 (08-30-2016)
Hi S,
Yes, one leg of the cotter pin was original bent.
And after repairs the new cotter pin should be bent.
Regards,
Alan
Regards,
Alan
jim
jim
IN THEORY, you don't need to remove the bolt completely, if all you're going to do is adjust the toe. You only need to loosen the nut and bolt, assuming it's not "rust welded" to the sleeve in the t/a bushing, so you take some tension off the shims, and shift them around as necessary.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here's a picture you can't get with the body on... but it'll give you a good idea about how much room is in there.
slickfx3 (08-29-2016)
With all due respect, you CAN'T be serious, are you? Look at it this way, if the wheels/tires are off, how would you get the car on/off the alignment rack? MANY wheel alignment adapters/sensors "clamp" to the rim. Without the wheels on the car, where would these tools attach? More importantly, setting caster/camber, and toe, either front or rear, requires the suspension to be "loaded". How would that condition occur, if the wheels weren't on the car?
The problem here, is quite simple....C-3s are at a minimum, 34 years old. 34 years of dirt, water, and corrosion, have made these bolts difficult to loosen/remove, hence these questions on "how to do it". I highly doubt that GM had 34+ years of usage in mind, when they designed this deal. So, if you're serious about getting your C-3s rear end aligned PROPERLY, your best bet is to obtain a new pair of the bolt/shims package that "Alan71" showed in his picture (above), install them in your car, then go to the alignment shop. For the non-purists, stainless replacement parts are available.
Having NEW parts in place, that can be easily adjusted by the alignment guy, will go a LONG way to getting a good alignment done to your car.
the PO had the bushings changed and hopefully the nut is not frozen etc
how can they get to the nut and bolt, if the tire is on the car? is it possible?
Yes!! Although the design isn't perfect, GM wasn't THAT dumb! After all, their dealer techs had to be able to align the cars.
I wrote this up awhile back when I did mine.
https://www.corvetteforum.com/forums...r-bubba-s.html
Took it to a shop afterwards and one wheel was spot on, the other needed adjustment. Hope it helps.
No matter what you do, take your own shims and the back ones are different. The original shop charged me for two sets, when one set will do both sides.
sssh everything with this c3 thing is a major undertaking
Don't use those phoney stock shims that Alan posted
Use SS washers from placeslike vbp
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
My alignment shop had no problem with doing the rear toe but did charge me extra because it was time consuming getting the toe dialed in.
what is a fair price? i heard 150 without the toe
I t appears that you aren't familiar with the rear suspension of a C-3. There's a U-shaped "pocket", as defined by a brace on the frame, that the nose of the trailing arm fits into. There are two holes in this brace, one on each side, that the "through bolt" for the trailing arm bushing pivot goes through. By "stacking" the shims between the sides of the pocket, and the nose of the trailing arm, you A) secure the trailing arm's lateral movement; and B) set the angle of the nose of the trailing arm, which, in turn, sets the toe-in.
If you're NOT going to set the rear toe, assuming it's out of spec, WHY BOTHER DOING AN ALIGNMENT? Secondly, if all you're going to do, essentially, is align the front end, then $150 is about $80-90 too much.....
You might be confusing the shims he's talking about. On the FRONT end, a C-3 uses the generic shims that cars have been using for decades. It's the REAR where the shims are A) different; and B) Corvette specific, and C) usually not something an everyday alignment shop has on hand.
I think you mean "SS shims".................
there are already shims in the pocket
question? do stock vettes come with shims in place?
