I just thought that I would post some of my old and present motors
All of them 383, 396 , 427, and the last 434 are all solid rollers
No wimpy cams with Crane Pro lifters. later cams got even bigger with .685/.714 lift
First 427 motown sbc
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Those are some healthy pieces right there!!
JIM
JIM
Impressive!
What did the 383 produce?
Very cool-looks like quality pieces.
Nice, Gkull is one of the few that actually beats on his engines, he broke a 4340 crank in half
That is the Comp Cams Poly dizzy gear made for non sleeved billet cams. They run fine and last a long time if you limit oil pressure to less than 70 psi. My present one has been going in and out of my different motors for years. Because I put it on my E-tech MSD dizzy and you can break them trying to remove and replace punching the roll pin
That's some serious go fast parts right there.
Pictures of the baddest per ci motor that ever went in my vette back when i was into NHRA ET bracket Division 7 drag racing.
3.875 stroker crank 4.030 bore for 396 ci 6 inch Manley H beam rods 13.8 C/R domed pistons using my Dart 227 heads running a Holley methanol carb I just broke so many things in the drive train that i gave up on drag racing after a couple of great years
