How to? Straighten warped Hard Top Headliner Panels
They stay in place but I have to keep pushing on the plastic clips to keep them in place. I've noticed that the two side panels and the main panel appear warped. I've not taken them off for closer inspection and wanted to get some feedback before messing with them.
2018 C3 of Year Finalist
Plastic velcro
Seems to be warped, a new one is 600.00 hope I can fingure something out. Maybe a heat gun ? Doesn't seem repairable ,good luck!
Received 1,126 Likes
Do you have the elongated J-shaped metal clips that slide into a slot in the headliner and screw to the body of the T-top? I believe there are three of them on each headliner.
I did try to straighten mine out with a heat gun but failed, probably because I wasn't aggressive enough. Regret throwing out my originals which maybe could have been recovered, but they're gone!
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
But if they are in great shape, put the gel in there... you'll never have to worry about them popping lose again.
Willcox
If the pads are in great shape and you don't think you'll need to remove them.. super glue gel on the Velcro and they will stay in place. There really isn't a way to re-shape the liner on an original liner, on the reproductions you can heat the back of the ABS and pretty much make them go where you need, then apply a cold rag to "set" them. But on originals the backing is different and it won't work.
Former Vendor
It will work for holding the velcro pads together. Fixing the wafer board pad where the clips are retained is a different subject though. I've used PC7 and another epoxy (I can't remember the name of the other one) on them in the past and had decent luck.
But you have to clean around the clip area with some thinner first, let it dry out and then use the glue. (you have to use a lot of glue around and on top of the clip). I've got a picture somewhere of one we repaired years ago I'll see if I can dig it up and post it for you.
Ernie
Here is the picture I just added to the tech site.
Hi Tom-
Update
I finally got around to installing my Hardtop yesterday. I have to use is as my son turned 16 and now thinks my daily driver is his (as does my wife but I'm not complaining) and I'll have to take my Vette to work from time to time this winter.
I did try to fix the warped panels but I don't think it's possible. The originals are made of cardboard and it appears that the main panel has some water damage at one point. I tried heat, wetting it (not too wet) and brute force with the plastic clips. I could get the clips to stay but they would only clip for a few minutes before coming loose again.
It's really not that bad (as see in the pictures) I just like everything to be perfect. It was cool to see the markings on the underside.
Markings, the "velcro" clips and the backing material (cardboard).
Where the headliner is warped the most.
Just showing my mounting hardware. I should find shorter bolts for the studs. To keep them from touching the soft-top I put these small foam pads on the nuts.
Maybe this summer I'll come up with a better mounting system other than the "velcro" clips. They hold great but won't hold the warped parts in place. I'm thinking of getting some interior screws and using them where possible.
Former Vendor
If they hold for a few minutes then the super glue gel will hold them. I will say, that while they are very expensive, I installed a new set of pads earlier this year and the fit was perfect... But we still had to use the glue on the two sides.. The velcro is still an area the repro stuff needs work in but I doubt it will ever change.
Willcox
Willcox
Former Vendor
Ernie
Some two decades ago, when buying my '72 vert, it came with a hardtop, and the liners were grossly warped, what caused it was the silly vinyl had dried out and shrunk, since the backing was some sort of paper/cardboard based stuff, it pulled the shape way in hell outta there, I tried a good bit to fix the 3 pieces, but no go....
I finally pulled the vinyl off and scrapped it, took the paper shells outside and soaked them with water, nice and flexible, left them in shape to dry in the sun a couple daze.....
then bought some nice soft fuzzy black cloth and some thin plastic soft liner material, and glued it all in place with spray adhesive.....lasted over a year up north, and down here in Florida, the hard top hung from the garage ceiling for about 5 years, grew tired of looking at it, sold it.....the guy was shocked in that the paint and interior of it were better than his CAR.....
How much did you get for your HT? I'm wondering if it would hurt the value being mine is totally stock.
Willcox - How much different is the finish on the repop liners as compared to the originals. I'm thinking there should be someone who could refinish original panels with new vinyl if they make repops.
Since you're in the parts business maybe you could ask around?
Former Vendor
The issue with refinished panels is the old sub-straight warping. They are impossible to correct so putting new vinyl on on subs isn't a good idea. Plus by the time you spend doing that you could probably pay to just get the new ones.
Willcox
Willcox
Glue recommendation
Is is there a specific super glue gel recommended that works best with these plastic to plastic adhesions?
Willcox
Willcox
hunt4cleanair (03-01-2018)
I fixed mine,I took a hand saw and cut groves in the headliner
Parallel to the rear window about 1/2 inch apart 2/3 of the way
Through the head liner. Nerve racking but it worked . Along with soaking
The vinyl headliner with conditioner to make it playable. It does work.
Contact cement on the Velcro was not an option to me.
1. Did you cut the back of the headliner through the board material - not the actual vinyl correct?
2. Why horizontal to the back window? Just based on where you were having issues getting the headliner to "stick"?
3. What conditioner did you use?
The fiber board for ME was fine some 25 years ago.....
the trick was to kill off the vinyl lining, dried out junk....the shrinking of it pulled the cardboard off the shape......
SO to kill the vinyl and prop out the cardboard in the driveway and soak it with water for a day .....let it dry then line it with fuzzy yard good material I chose black with white marks......
it was fine, even here in Florida some 6 years later.....no need for it, so I sold it off.....
the guy who bought it loved it.....in the upper mid west.....
Thanks for sharing. Few questions:
2 mine was hanging down all along the glass. This left it go up
And stick.
3. 303,but I think anything like it would work. Heat gun too.
I did have. To use a couple of long Chrome screws on the side
Pieces by the door,looks fine better than 600 plus shipping.
