Borgeson leak
Borgeson leak
Installed a Borgeson steering and a hydro boost brake system. All works well except I have a small leak where the hose attaches on top of the Borgeson box. I've tightened it to the point that I broke one cheap line wrench so I got a better set and tightened it again. However it still leaks. Is there something I can put on the threads or some other trick to stop the leak?
here is the pic on Borgeson page http://www.borgeson.com/xcart/image.php?type=P&id=1759
Yep. Those bushings need to be there and seated. I made sure they were sitting straight and then took the open end of a 3/8" extension, set it on top of the bushing and gave it a pretty good tap with a hammer. Even after that the fittings had to be reefed down super tight. I've been running it for 3 months without leaks.
You'll get it!
Good luck to you!
You'll get it!
Good luck to you!
I had the same problem after installing mine. Even with the brass bushing seated properly I still had a small leak. I ended up using permatex hydraulic sealant. It's expensive, especially since I only needed a few drops, but it did fix the leak. I've been running it a few years now and no leak.
The reason Borgeson supplies those brass inserts is because the ports in the steering box were designed for this type fitting with an o-ring, not the inverted flare fitting they supply with the kit. If they would supply the correct fitting on the hose, it would work better than the scab type inserts.
I took it apart and found that the small Ferrell was in fact there and seated properly so I put some teflon tape and a small amount of pipe thread dope on it. Tightened it up as much as I could. So far no leaks! Hope it stays that way
Thanks guys! I noticed when I took mine to storage I had a leak on hi pressure hose. I know sometimes fittings need to be loosened and retightened to seat but if that doesn't work I'll try to teflon tape and also make sure the brass bushings are installed. Thanks again!
These adapter fittings should take the place of the brass inserts and cure the leaks.
http://www.classicindustries.com/pro...arts/ff01.html
https://www.summitracing.com/parts/clp-605sol
I had to end up using teflon also, no matter how the brass insert is seated it would still leak on one hose (the one closer to the firewall).
hasn't leaked since doing that but if it does going to look into that fitting above.
ok so mine starts to leak afer a couple months with the teflon tape or liquid stuff.
has anyone used the above fitting?? or just use the hyrdaulic sealant?
it seems odd to me that Borgeson would include a hose that doesn't go into their steering box properly.. cause they supplied both parts... definitely disappointing after all that work for it to keep leaking, getting tired of this want to find a permanent fix.
Update* I ordered the above fitting from summit, they had it for like $15. if it fixes it that will be awesome, will post an update once I install it.
part number is CLP-605SOL
Two questions
Secondly: how does your steering feel when cornering during (heavy) breaking?
Thanks!
in my case you can see a little fluid sitting at the top of the threads on the fitting after a while. and of course there is the small puddle that you find on the floor beneath it.
steering feels great at all times when cornering, the feeling of shooting to one side is completely gone.
I just ordered from summit they seem to have it in stock, and better price too
getting the old brass ferrule out will be tricky, I had to really tap it in there when I first installed it.
last time I undid the fitting the ferrule did not even budge a little when I tried to take it out to re-seat it.
My leak wasn't hard to trace. As one had already indicated there was a small amount of fluid around the top of the fitting where it screws into the steering box and then a small puddle on the flange just below it and then some that dripped on my header pipe also.
Ali Vette, you are correct about getting the ferrule out. When I redid mine I thought I would just remove it and put another new one in but I could not get it out not matter what I did. I was afraid of damaging the threads so I left it in and used the tape and thread dope.
I'll see how this holds up and if not then I'll opt for the bushings above and figure out how to get the ferrule out.
As for the steering it never has been the dramatic change I was told it would be. However I have also been told that until I rebuild the rear suspension, including trailing arms it will never operate like it should.
its interesting that you have the same ferrule issue, I am thinking the outer diameter is slightly too large, it never even seemed to fit properly for me. I read about ordering another size ferrule but this adapter piece seems way better.
I'll report back when I figure a way to get the ferrule out, one way or another its coming out... worst case I am thinking I can use one of those reverse extractor bits on it since there is a hole in the middle shouldn't have to drill at all. I find it ridiculous that the kit does not have this simple adapter kit in it, I am sure tons of people have installed it before.
my power steering wasn't ever working before and would dart to the side under breaking, so compared to that its been a huge improvement. I can see the rear suspension playing into it but mine seems in decent shape but I def need new shocks.
Just to update, I used the fitting and hydraulic sealant and all was good for a while, then It started again after a few months. still not sure how it could leak after all that but I am going to take it apart again and have another look. I regret not going with the rack because this leak is really bothering me. not only does it leak on the floor but it leaks right onto the new steering ram thing that comes in the kit and I am afraid its going to wash out the grease and cause issues. I already repacked it with grease once...
Has anyone made a new hose that would work with the o-ring ends. at this point I wouldn't mind running a better hose. for now I am going to open it back up and clean and reseal it and hope for the best.
