69 Stingray rear suspension ride height adjustment
Received 2,878 Likes
Hi APG,
Here's the info on the spring specs from member John Hinkley.
"Both the Chevrolet Engineering Specifications package and the AMA Submission detail show the 9-leaf spring with a rate of 140#/inch at design load (1360#). The 7-leaf F41 spring is 305#/inch at design load."
Regards,
Alan
These original leaf end details may help you decide if you currently have a GM spring or aftermarket spring. Note amount of 'curl' and ground/cut(?) taper.
Regards,
Alan
Hi,
The 71 AIM Trim Height Charts/Diagram indicates a different set of ride height dimensions for a F41 equipped car compared to a std suspension car…. NOT MUCH (1/2")… but slightly lower.
Regards,
Alan
Regards,
Alan
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
you can parts from any of the vendors, I prefer Willcox, call and talk to them, sometimes they run a weekend sale on parts, they also have great videos on replacing and repairing parts on cars. call and talk to them or email them.
My '71 ride height from the floor to the top of my wheel well is 27 inches front and rear. I do have big block springs installed in the front and a composite spring in the back so I am not stock.
#33
That top bushing looks twice as thick as my stock 72. Take a look just in case. That would lift the rear some.
#34
AGP22,
I might be seeing things here but if you check the first or top pic in your post #12, do you have the top bolt backing out in your half shaft flange to spindle? It sure looks like it in the pic....
My 69 big block still has the stock 9 leaf with all new rubbers and ride height in the rear (floor to fender) is 28" and 27.5" in the front.
#35
Remember after jacking etc. move the car forwards and backwards to get the ride height to settle. The way the rear independent suspension is designed when coming off jacks or a lift the rear wheels are toed in at the bottom causing the ride height to be too high until you move the car. If you cut the straps then maybe you need to move the car and settle the ride position without the straps.
How dd you get your car to sit so low? I had to cut a coil and heat and bend the cut coil to get my car down to 27" in front, rear I have 9in bolts planned.
#36
I didn't do much other than install the big block front springs (which are shorter than the SB springs by a little. It says that these springs will not effect the ride height but I can't see how it can't as the BB spring (higher spring rate, shorter overall spring) was about an inch shorter than the stock SB spring I removed. I'm looking for pictures but it's been about 10 years since I did this work. I installed the 360Lb composite spring with the stock bolts and Van Steel offset trailing arms (that shouldn't contribute to lowering that I can see).. I really wasn't looking to lower the car just do some upgrades. I didn't measure it before I did my suspension work so I'm not sure if it lowered or not. It may be my worn out body mounts too.
#37
Sorry, My box is full.
