Dry sump for a big block C-3- racing
2021 C1 of the Year Finalist - Modified
Anybody here run a dry sump system on their c-3 for road racing ? I've bought the best baffled pan I could find and still have a nagging feeling it's not going to work in a long banked turn. Could be a very expensive mistake so I am going to dry sump it this winter. Anybody done this that could post a couple pics for me? Do I have to notch the front crossmember ? Best place to put the tank? How to run the lines ? I am going 4 stage or is 3 stage enough? Hmmm.
No baffled pan can supply consistent oil pressure on cars exceeding 1 G turns
I cheaped out and installed a 4 quart Accusump on the passenger side roll bar
I've worked on numerous cars with dry sumps. They have a Hp advantage. The hot oil tank in the driver's compartment always bothered me
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Might do a search here on threads by 632C2 from a few years back. His '67 had a 632 in it with a dry sump arrangement. More 'drag race" inspired, but same components. He had a tank built that fit in the "gill area" and managed to get everything to fit nicely.
JIM
JIM
I've got a lot of money invested in my engine, I'd hate to loose it due to oiling problems. Does the accusump really work ??
I agree and I don't think SVRA allows oil tanks there. I cleared out the AC unit and am thinking of putting it there or behind me.pass side
Thanks, I will search some more
HMSA really doesn't allow dry sump additions to cars raced without dry sump back in the day. but they understand the need for owners to protect their motors. We got caught during prerace inspections on Bizzarrinis with dry sumps that were very hidden. It is a talk with the race promoter at that point.
I worked for the shop that has had the winning cars in several groups at the Monterrey Historics. The group 6b winning car for the past 15 years or so has a 4 quart Accusump.
OFFICIAL ROLEX RACE RESULTS
Rolex Monterey Motorsports Reunion
Date: 8/18-21/2016
Mazda Raceway Laguna Seca
Length: 2.238 Miles
Group 6B - 1963-1966 GT Cars over 2500cc
Pos
No.1
Name
Hometown
CarDescription
Laps
BestTm
InLap
1
75
Thomas Steuer
Bogota Cundinamarca
1965 Chevrolet Corvette
10
1:41.935
6
http://www.mazdaraceway.com/race-res...n-race-results
I can't speak for a big block but I have run a Canton road race pan on a small block for 20 years with no issues. I have never seen the oil pressure light blink in all that time.
You are probably just not going fast enough yet! Yes, but are you running slicks or grooved Avons? Even improved Canton pans are not enough in fast cars to prevent periodic loss of oil pressure. It also tends to be tracks with long flat turns
I will be running Hoosier slicks and hope to run at Indy and the Glen this yr. My formula car will corner at 2.5 G's and brake at 3 G's, I hope I can do the Vette proud.
Received 3,218 Likes
I'm doing a 3stage dry sump in my 71. Not a Big Block (or even a small block ) but a BMW V12- I could not use the stock in pan oil pump because of clearance. However the engine is about the same size as a big block for reference.
I'm running a 10qt Canton tank- tight fit inside the driverside fender- I've removed the vacuum tank (running electric headlights) and the clutch bracket (running Hyd system).
Here's some pics- this is a street car- running the stock external BMW oil filter canister- that won't leak down when the engine sits- even for extended periods- something to think about -not wanting to prime the engine.
And since it's a street motor - I have set the pulleys pretty close to a one to one ratio.
Since it's tucked in the fenderwell- and draining the side plug would have been a pain- added a drain plug on the bottom- and even have it threaded so I can use a hose to direct the oil in the drain pan- also have a hose on the breather.
One thing I didn't do- and will later- is add a oil door in the top of the fender- for easier access.
Originally was using a Petersen but got a great deal on a "Nutter" 3 stage oil pump.
Here's a good website on Dry sumps-I spoke w/ the owner on setting up mine.
http://nutterracingengines.com/racin..._products.html
And was able to add a Lokar dipstick -
DSCN5198 by Richard Hayes, on Flickr
DSCN5154
DSCN5088
DSCN4680
DSCN4080
DSCN5154
DSCN5088
DSCN4680
DSCN4080
NICE ! The pics give me a few ideas. That Nutter pump looks good, they have been building race stuff for a long time and they have a good reputation. Their engines have won a lot of races.
Gee's, after 20 years of road racing, I just now find out that I am not going fast enough. Thanks for the tip. I guess that this explains why I come in third or fourth every once in a while.
I would tend to say that if you are going fine for 20 years you probably don't use road racing slicks and your car has a lower power to weight ratio
Track design also plays a factor
As I was around faster and faster cars I saw more and more failures. I just don't want to take a chance on my over 10000 dollar motors
Yer doin good ! The guys I'm gonna be racin with I would be thrilled to finish 3rd or 4th !
Like I said. As g force increases the ability of the pan alone ends
what track do you actually race at? I talked to a racing friend and he has a two car race trailer. We discussed finding a series of tracks in the western states and figure their racing schedules and how to be hitting a different track every week starting in the spring. Just cruise around and see the sights for a few months doing a big loop.
FWIW, having experienced loss of prime on a few occasions during long sweepers (even with some of the items listed below already installed), shy of going dry sump I'm throwing everything else in the book at mine that I know to do. 5-gate RR pan, rear main baffle*, crank scrapper, modern one-way windage screen*, submerged & pressure balanced pump, massaged galleys & returns*, Glyptal painted valley, low restriction filtering (doesn't necessarily mean low filtration), and 3 qt. Accusump*. If that doesn't do it, then I guess dry sump it will be.
TSW
* New items.
TSW
* New items.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
TSW
* New items.
TSW
* New items.
I don't racw big blocks, although I own a 435 car, we use Dailey pans and pumps and Peterson tanks on our LS race Corvettes. Call Bill Dailey and talk to him.
http://www.daileyengineering.com/dai...ering_home.htm
