Power Brake Booster Vacuum Question
I noticed that when I perform a vacuum check on the power brake vacuum booster, the vacuum holds until I push the brake pedal in. As I depress the pedal, all vacuum bleeds off and the booster is is nothing more than a vacuum leak. I used an electric vacuum pump to perform this test. Is it supposed to function this way?
i noticed that when i perform a vacuum check on the power brake vacuum booster, the vacuum holds until i push the brake pedal in. As i depress the pedal, all vacuum bleeds off and the booster is is nothing more than a vacuum leak. I used an electric vacuum pump to perform this test. Is it supposed to function this way?
DUB
KJL (12-18-2016)
Before you go spending money throwing parts at your Corvette in hopes of fixing your problem, first post up what cam you are now running with the cam specs. Low vacuum reading can be caused by more than just a bigger cam. I have run cams with 242/248 duration @.050 with an 850 DP and still have enough vacuum for brakes.
You may just need to do something very simple to get your vacuum reading back up to where your brakes function correctly. Things like lack of ignition timing, or an overly rich carburetor setting can kill vacuum, as well as having the valves adjusted too tight. All can be fixed without spending money on new parts.
Scott Liggett
BluePrint Engines
Product Specialist
Scott Liggett
BluePrint Engines
Product Specialist
Scott Liggett
BluePrint Engines
Product Specialist
Scott Liggett
BluePrint Engines
Product Specialist
My cam is 257/263 at .05. I run a locked distributor with timing set to 34 degrees. No vacuum leaks and carb is a 950 Holley with mech secondary’s. I tune with a wide band O2 meter. My vacuum is around 10” at best ant that is at a 1200 rpm idle. If I tinker with it I can get vacuum to close to 12 inches but that leans it out a little too much.
What size engine is this?
257/263 duration with anything less than 112* lobe separation angle will give it one heck of an idle note, but all that overlap will be tough to make vacuum.
If this is a street car, why are you running the distributor locked out?
10-12 inches of vacuum at idle is borderline for brakes. Do you have any vacuum assist at all? If so, maybe all you need is a vacuum resevoir can.
some one mentioned vacuum reservoir tank could help. I installed one on my vette and it doesn't help much. once the can is full it works ok and then it doesn't full up quickly. so then you have a spongy brake pedal. Some member's run a vacuum pump and claims it works great but is noisy. I'm looking at installing a leeds vacuum pump which is not as noisy and puts out 25 PSI. check out their web site and review their video.
Just be careful to pick the brake pads for street use. Some race versions don't work very well until they get hot. Very scary on the street and would make matters worse. I am sure Hawk's website will have such warnings.
CI 5 & 8 Veteran
Bullshark.
"It is a 434 small block. Engine dyno at 700 HP and 570 on a dynojet at the rear wheels. The best I can do is about 10 inches. I am going to try some Hawk performance competition brake pads on it to try and improve the “grab”."
I think your at the point where you need to convert to manual brakes or convert to Hydro boost assist.
