Exhaust header for 1-1/2 x 1-1/2 square head ports?
I'm buying a crate engine for my '75 and the manufacturer said their cylinder head exhaust port is 1-1/2 x 1-1/2 square. I need to buy some new headers but can't find anything that exactly matches that port on stainless steel.
I'm thinking of getting Hooker Competition Headers 2476-7HKR that have a primary of 1 3/4 but oval shaped. Will the increase in diameter make up for the port mismatch? Will they fit fine in my C3?
I need to get them from Summit Racing and they also have the same headers with a D shaped port but I think oval will be closer, right?
I have the hooker S/C 1 3/4 headers. Because of the tube size you need little tiny 5/16 nuts to clear the tubes. Header studs are the only way to easily install and remove headers
You need these items
https://www.summitracing.com/parts/fel-1404/overview/
https://www.summitracing.com/parts/a...1411/overview/
I put a dab of high temp red permatex on the 5/16th nuts to help ensure that they never back off
fede (01-04-2017)
Which headers did you get? The 2105-7HKR? I might get those but wondering if they will fit fine in the car with enough clearance to everything else.
BTW, those studs are really expensive!
Mine are 25 years old and have been recoated about 12 years ago. All my motors use studded exhausts. bolts tend to loosen with heat cycles. Early on i tried locking bolt ideas with limited success. Then i figured out that fully studded motors are the only way to build quality motors.. I like Spain and have spent quite a few times there.
https://www.summitracing.com/parts/h...model/corvette
Milder motors don't require 1 3/4 primary pipes. So you might just use 1 5/8th. in motors of let's say less than 400 hp
Received 1,722 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Also, if you have a die grinder you can massage the flange of the header a little to line up with the ports better.
I have these ceramic coated and like I said 25 years old and I have stainless steel 1 7/8th that I use on my 434 ci small block. Stainless discolors into blue and brown really fast. I have 3 inch exhaust with an H pipe and 3 1/2 inch in and out mufflers to keep the back pressure low
fede (01-05-2017)
For future reference...
I called the tech support from Hookers and JBA and ended up with these 3 options:
Doug's Headers D334
Hooker Super Competition Headers 2134-1HKR
JBA Headers Cat4ward Headers 1815S-1JS
(there was a 4th from Flowtech - Shortie 1 5/8 but can't remember the part no.)
The JBA's are stainless steel shorties, so shorties that look more like a manifold and 1 5/8. I wanted full-length.
The D334 and 2134 are very similar: full length, steel, ceramic coated, 1 3/4, 3" collector.
I ended up buying the D334 mostly because they have a 3/8" flange instead of 5/16 and also they were cheaper and included the collector reducer I needed (3" -> 2.5")
Doug's Headers D334
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
For a 450 HP 383 I'd use 1-3/4" headers.
JIM
JIM
