Transmission Removal
I just pulled a Muncie from a 68. Fixed crossmember although it does have side pipes which makes it easier. Converting over to a Tremec TKO 600. 6 hours later it is installed with a new clutch, bellhousing is indexed in and the only thing I'm waiting for is the driveshaft. That should arrive tomorrow. Its a tight squeeze getting the Tremec in with a fixed cross member but it can be done. This I think is my 8th install of one of these so you learn a few tricks along the way. Also helps I have a 4 post lift and a trans jack.
Well, I think you got your answer, but to contribute my little part.....
Before I made my crossmember removable I removed the Muncie M-21 out of my 68 by following most of the hints mentioned above. I also removed 1 or 2 (don't remember) of the aft bolts on the tranny to give me additional 5/16" to 3/8" ..... this allowed me to pull the Muncie as far back against the crossmember as possible, and to slide the front of the input shaft along the rear face of the bell housing, as I tilted the engine down at the same time (and, yes, I removed my distributor).
PS- I now have a removable crossmember so it's a non-problem to remove and replace my tranny.
Yes. It can be done and I have done a bunch of times now. Strip everything off the trans before trying to remove it. It actually comes out quite easy. The Tremec takes some effort and you put the trans back in before putting the bellhousing on. You have to wiggle the bellhousing up there while you have the Tremec going in. It can be done but as I said I have a lift and trans jack but I do it by myself also.
IDOXLR8 (11-07-2017)
Got me by 2 years! 60, I took every thing out of the way including the shifter bracket.
The first one I did was my car and I made the cross member removeable. I did this knowing I was always changing things out so I wanted an easy removal process. I'm glad I did as I had it out multiple times for various reasons. Now I run a T56 6 speed and had to heavily modify the cross member and no way can yo udo this with a fixed cross member
Received 1,114 Likes
transmission jack
As I said I have a lift and trans jack (Got a lift but not a jack) which makes it a lot easier, but I had only 1 set of hands also (Me too). I then have 2 long studs i screw into the bellhousing and slide the trans on these. (Got these!) If the clutch is lined up it will slide right in and bolt it up.
I wouldn't mind seeing picture or description of the transmission jack you use, Gordon. In lieu of actually buying one for a hypothetical clutch job that I don't know I need to do yet, I made the enclosed rig to attach to my floor jack. Seems to have the requisite degrees of freedom with the exception of having to horse around the tranny on the arc of the circle I cut, rather than turn a screw to change the angle.
This cradle is for a Muncie and car has a conventional bell housing. Think it will work?
This seems like a good place to ask this question. I am not sure if I'm going to have to replace my clutch yet, but I thought I'd do all the prep just in case. Last time I did this I borrowed a friends very expensive (but old) transmission jack and it made the job a whole lot easier except for the fact that I had to rebuild the thing in the middle of the job because it leaked and various and other sundry problems.
Correction, Looks like it was a Harbor freight one. It lists for 199 but I know I paid about 7 years ago under 100 dollars. I dont use any of the attachment on the top plate but it is tiltable. I never had to strap it down or anything I just hold onto it because yo ujack it up with your foot.
https://www.harborfreight.com/1100-l...ack-33615.html
Thanks for the long reply, Gordon. I should be able to tilt the transmission on this rig by sliding the curved pieces along the arc I cut with my bandsaw. Maybe my second picture makes this clearer. It won't move easily with the weight of the transmission on it but at least it should stay in place (the aluminum plate is just resting there so it doesn't get lost. It fastens to the jack). I don't think the tranny would ever need to be in this orientation with the input shaft pointed up. It's either level or the tail tilts up to clear my factory crossmember.
#33
