Transmission Removal
Has anyone replaced a clutch in a 79 Corvette with a completely original exhaust, this car has a Borg Warner Super T10. I know the exhaust is in the way on the true dual exhaust cars, my question is will this transmission come out with out moving the exhaust and has any one did this? Thanks in advance, AL.
Transmission Removal Question
For what its worth, I've pulled the automatic trans out of my 77 a few times. That required removing the trans crossmember which required dropping the exhaust. I have headers so that wasn't too bad. I don't think you can get a manual trans out without dropping the crossmember either.
As for if the exhaust is in the way, I'm not sure.
I have a 79 4 speed vette without the original exhaust. My crossmember is welded in. When I remove my transmission I have to first remove the shifter and all linkage, the little mount bolted to the crossmember and all bolts, cables, etc all. Push the tranny as far back as you can and the front input shaft will just clear the bell housing and you can drop the front down and the tranny will slip right out. Installation is the reverse.
Hope this helps.
Hope this helps.
IDOXLR8 (02-07-2017)
I have a 74 4 speed car, and assume that your set up is the same or very similar to what mine was. I suspect that as someone else mentioned, your crossmember is not removable, the same as earlier years.
If you've been considering side pipes, and a hurst shifter, now is the time.
I can't imagine any way that the trans can come out without disturbing the exhaust.
You are going to drop the exhaust, enjoy disconnecting the factory shifter from the crossmember [if someone hasn't already done you the favor of putting in a Hurst], and then pulling the unit back, rotating it, getting the input shaft to angle towards the passenger side, and then maneuver it out.
Do yourself a HUGE favor, and cut the crossmember out of the car, and have mounting tabs welded on.
I did my clutch back in 2010, and recently swapped in a Richmond Overdrive... this time I cut the crossmember out.
i understand your issue.. original exhaust means that the manifold studs WILL break when you try to remove the exhaust.
When I have removed a corvette transmission 4 speed, everything was removed and up out of the way.. makes the removal/reinstall an easy one man operation..
... so, I don't know your answer so I whipped out my '70 chassis service manual.
It says to remove the right and left exhaust pipes....
not sure if the same procedure for applies to your 79. I expect it does.
Hope this helps.
Hope this helps.
You might be able to fish it out in pieces. Unbolt the shifter and separate the trans from the bellhousing. I had a similar problem with a GMC truck and I cut the pipes about a foot down from the manifolds. I used stainless steel band clamps to resecure the pipes. You can also get a competent welder to weld them in place.
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
Hope this helps.
Hope this helps.
From my experience, if you don't do it this way, you'll have nothing but grief. Some recommend rotating the tranny and it will come out. Well, that doesn't work on my '76 and probably won't on a '79. I can't speak to your exhaust pipes. I have sidepipes and this alleviates alot of undercar headaches.
Royal Canadian Navy
Maybe I was rotating mine the wrong way because it didn't work for me. It literally fell out when using the method described. It also slipped right back in when using two guide bolts.
The tail shaft is off set, and when rotating it clockwise allows the tail shaft to go back more into the tunnel.
Royal Canadian Navy
Mine didn't. It was catching up on the shifter bracket. So, I removed all that stuff. I'm not the only one who has run into this problem. That said, doing this alone under the car on 18" jacks at 62 yrs old maybe a contributing factor.
