Will aftermarket chip allow bigger cam in 82 CFI?
Not talking BB solid rollers, but cams in the 110-112 centerline and sub 220 durations ?
Like the CompCams XFI series or Lunati 60101?
Intake already ported or Renegade installed.
Years ago, I was working on a Camaro the owner had stuffed a way too big of a cam in. I called around and found someone that could custom burn a PROM based on the desired base and total timing and the engine idle vacuum. That car went from a PITA to drive to a beast- with a decent idle.
FYI, I started with a TPI unit changing EVERYTHING (from comp ratio to heads to manifold, runners plenum, throttle body, cam, custom chip, headers & exhaust) before it got to where I was satisfied.
The problem with the 82 CFI is that the manifold runners are VERY restrictive. You may get something from the cam change and custom prom BUT, physically you can't get enough air into the cylinders to get kind of power that would justify the work and expense of the change.
If your talking the Jet Performance chip, then no. Due to EPA regulations, it only changes the WOT settings. The smog settings remain the same.
Even with a different intake the throttle bodies become a restriction. Your spending alot to keep something that isnt what it was . I know people think they look cool but you dont drive with your hood open.
Id suggest doing what a friend of mine.did, he polished his crossfire intake then put it on the shelf so people that didnt know better thought it was some experimental part.
Eddie Motorsports Renegade Crossfire intake manifolds have been specially-developed for vehicles equipped with the dual throttle body GM Crossfire fuel injection. They're the only true OEM/high performance manifolds produced for these engines. Manufactured in the USA, their advanced runner profile design, increased plenum area, and flow enhancements provide improved power, torque, and gas mileage. The Eddie Motorsports Renegade Crossfire intake manifolds will accommodate modified throttle bodies up to 2 1/4 in. bore and accept all of the stock accessories and brackets--as well as EGR, PCV, and stock vacuum fittings. They will also fit under the stock hood of all Crossfire equipped vehicles with no modifications necessary. These manifolds include stainless steel fasteners for the top plate, throttle body base gaskets, and air horn gaskets.
Zen Vet Master Level VII
You will WASTE YOUR MONEY on a cam without changing the intake manifold.
Don't worry about the computer as you will adjust the timing and fuel pressure independently and your computer will then adjust.
Get yourself a Renegede manifold and pop in your cam. You will run well.
Hit up Buccaneer on the CF and he will steer you straight.
I'd upgrade to a better ECM that you can actually program so you get the most gains from any engine modifications you do. Use a early TBI computer with an emulator so you can do real time tuning or use an early TBI computer modified with a dynamic-EFI upgrade so you can flash program it. The earlier TBI computers like the '7747 can easily be programmed and will swap in and pretty much all the wiring is in place you just have to change the connectors.
