1972 radio needs fixing
5th Gear
Hey guys,
Just wondering if you can point me in the direction of a good delco radio technician? My radio is complete and in good shape but I can't figure out it's issue.
Thanks for all of your time and info.
William
William
Received 1,469 Likes
Cruise-In II Veteran
Have you done any troubleshooting? What is it not doing?
Received 2,878 Likes
Hi William,
Welcome!
You might want to try:
D&M Restorations in Greenville, S.C.
(800) 722-0854
Regards,
Alan
Welcome!
(800) 722-0854
Regards,
Alan
5th Gear
Well I took it to a guy that use to work on electronics. He said good news is there is no blown capacitors. Bad news he couldn't get the proper voltage. I believe he replaced the voltage regulator but not sure. Then he just didn't have time to continue with it. So I took it and got a delco schematic book and started trying to trace circuits. Forgive me for the vagueness, this was last fall. But I believe I found an area where it was supposed to reduce down to 6 or 8 volts and it was still at 10 volts. But there seemed to be power everywhere I tested that was supposed to have power. At that point I figured I would just have to send it away to be fixed.
What it is not doing in the car is not put any noise static through to speakers. All that happens is the dimmer light turns on in the station display.
Thanks again for your time.
William
William
5th Gear
