700r4 to LS
I have a krazy custom intake on my car, and so a custom throttle bracket for the cruise and accel of course......but the 200 trans uses the same throttle set up as the 700, I just ran mine through the floorboard, essentially straight up, over the ducting/ past the instruments, got a steel plate welded to the bracket going from steering column to console, and cut a square hole in it, and ran it down to the gas pedal, with a rubber lines clamp on the lever and some careful adjustment as to position, which is about 2-3" above the gas pedal, the trans loves life....
http://paceperformance.com/i-5138040...smissions.html
There is a spacer listed on page that you also need.
