Woke up this morning to the smell of gas!
#41
My '74 doesn't have an EGR valve. It's got an LT-1 engine from a '70 Vette. so I'm not sure what's correct. I bought it this way and it's always run great for 34 years. In the pic below, the PCV valve connects to the large port on the back of a Holley 750 carb.. The small line from the canister is the one with the arrow. It connects to a brass "T" on the manifold at the back pass. side of the carb. That brass "T" has a large port and (2) smaller ports. The large port connects to the power brake booster. One of the smaller ports goes back to the carbon canister labeled "CARB". The other small port tee's to the TH400 modulator and to the head light vacuum circuit. I'll probably need to try and look at a '74 with an L82 and a '70 with an LT-1 engine to try and figure this out or just put it back together the way it was only with a new canister and a new fuel separator valve.
#42
Tooch
Peterbuilt (03-02-2017)
#43
Hi G,
My understanding is that for the 70 model year the Evaporative Control System was installed on all cars scheduled to be delivered in California.
The system was called out as rpo NA9.
It wasn't required on cars being delivered to other states.
Because it requires a different gas tank and cap I don't think it could have 'casually' been added to cars.
Regards,
Alan
Regards,
Alan
Graham
#44
If it has been a good operating system for 35 years, I would leave it as it has been, replace the fuel separator and rebuild or replace the canister and run it another 35.
