Max 17 inch tire size on a 69?
I recently got a 69 and am going to get 17 inch wheels and tires. If I get a 17 x 8 torque thrust 2 wheel, what is the max 17 inch tire size I can run without rubbing? I see posts about later years but is seems like the 69 may be tighter because it doesn't have flares. Is that the case?
GW, I'm going to try to change your mind. From research when I was looking at wheels for my 69 I found that tire manufactures are loosing interest in the 17" sizes, due to the auto manufactures going to larger wheels. Purchasing wheels is a large expense that you only want to do once. I purchased 16's for my 6t8 some 20 odd years ago and I can not get tires for the rear wheels any more. Some of us here have discussed that will also happen to the 17's. I'm running 18x9 4.5 b/s on the front of my 69, stock suspension with 255/40 tires. The only modification needed to the rear suspension to run 9' with 4.5 b/s wheels is relocating the parking brake calbe mount. My spare is a standard Gr60x15 If you check Tire Racks web site they give all the specs for the tires, recommended rim width, diameters, etc, which I found very useful when choosing a tire size. A 26 to 27" diameter tire size is what just about all c3s are running, just match that to the recommended wheel width you decide on. There is a sticky above on wheel and tires, do your research and make an informed decision. T
Don't know if this is the maximum that can be ran on a 69 but it is a very good handling tire and is 26.6" tall so it looks correct on a C3.
Michelin Pilot Sport PS2 size that came on Porsche Caymen so they should be around for a while longer. I ran them on a 76 for several years.
https://www.tirerack.com/tires/tires...S2N1&tab=Specs
I have 255/50/17 ZR's is the rear and 255/45/17 ZR's in the front on my very early 78 with zero rubbing using the SLP 17 ZR-1 style rims no longer made...My inner fenders were never modified or cut by GM for the OEM 255/60/15 rims/tires.
Here you go 1969 with the wheels you are considering running 255/45x17
The following 3 users liked this post by MelWff:
about 22 years ago I got a set of 17x9.5 rims off a '92 vette switch for style reasons many years ago to 89 vette rims....sale size...
using 2.5" VBP adapters, I have 275/50/17 in rear, having move the ebrake tab to behind the caliper....
255/50/17 front, limited the steering radius by building out the lower A arms rub blocks......
my car has the equivalent of late shark flares on it....built out another inch or so over stock '72......
245 x45x17 rim width 9.5 2.25 " Adapters tires flush with wheel well.
No suspension changes.
69Vett (03-03-2017)
gleninsandiego (03-04-2017)
Very Nice!!!
Personally I feel the 255/45/17 ZR tires are the best looking, handling, Steering responsiveness and comfort riding tire for the C3 with 17's. The key to the 17/18's is to reduce the bubble sidewall look and effect of the 15 in tires to achieve the noted advantages above. I have 255 /50/17 rears with 255/45/17's in front since with 3.70 gears and the 4 speed, I did not want to reduce the overall diameter of the tire, thus numerically increasing the rear gear ratio...it revs too high to begin with on the highway. Maybe someday if I go for a 5/6 speed OD tranny I could put the 255/45/17's all around.
The following 2 users liked this post by jb78L-82:
gdh (03-04-2017),
