Anyone have these Finned Aluminum Valve Covers on a mid-70s L48??
I have a base L-48 in a '77 with A.I.R. I am just going through the car and getting leak areas addressed. I have been looking at replacing the stock stamped valve covers with aluminum, but prefer not to drop $225-$250 on a new pair of L-82 type aluminum covers.
After looking at several styles, I really wanted to get these classic style Chevy finned covers. However, it appears I will have clearance issues (EGR valve, A/C brackets, PCV hoses, etc.) judging by the measurements listed.
https://www.summitracing.com/parts/cal-196187/overview/
So, does anyone have this type of cover on a similar setup as mine that will be close in height to stock covers?? The height of the stock stamped covers looks to be about 2.5"
I may just have to strip down and paint my stamped covers if I can't find anything to fit.
Received 2,878 Likes
Hi rd,
Doesn't a 77 still require that one of the valve covers have 2 holes in it?
(pvc and oil fill?).
Regards,
Alan
Regards,
Alan
Hi Alan,
The driver's side does indeed have oil fill and PCV. I had planned to do oil fills through the PCV hole on these type of covers. With baffles in the covers, it would just take longer to fill.
Hi rd,
Well o.k.!
Regards,
Alan
Well o.k.!
Regards,
Alan
My base 69 had factory stamped covers. I replaced with good used L46 finned aluminum units from ebay. I had to watch for a while but after about 6 weeks a nice set came up for $60.
They were very dirty from the ebay pics so I assume that is why no one else bid on them. A few minutes with some carb cleaner, an old toothbrush and a little time with some fine steel wool they were presentable.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,924 Likes
Regards from Down Under.
aussiejohn
Dementer sole survivor
Received 6,278 Likes
2016 C3 of Year Finalist
Scott
Thanks for the replies gentlemen.........
I should have posted a pic first to show what I've got. My primary concern is clearance with new finned covers. On the pass. side, I have the EGR, A/C bracket and one of the A/C hoses.
The covers that I linked have an outside height of over 3.5 inches and my preliminary measurements make it appear they won't fit. So, I didn't know if anyone had covers like this with a shorter height and a similar engine setup like mine.
Barrist- Is your setup like mine (EGR, A/C, etc.)???
The more I look at it, I may just strip and repaint my current covers and see if I can pick up a cheaper set of finned L-82/L-46 covers down the road like DynaRockets did. There are so many danged hoses covering things up anyway.
Urge to perform A.I.R. delete........rising
That's the Victor Junior single plane. The engine dyno'd at 500/500 with massive low-rpm torque. Last summer, I thought I'd try the advice that everybody dishes out and buy a Performer RPM Airgap. What a mistake... the RPM Airgap lost torque and power at every point in the power curve, including off idle. I yanked that stupid thing back off, sold it on FleaBay at a 50% loss, and put the Victor back on. Now I have my smokin' performance back, and I'll never consider running a dual plane on a real performance engine again!
Lars
Dr. Detroit
Received 3,892 Likes
Scott -
Lars
Lars
Jebby
Jeff -
You must not read Hot Rod Magazine... single plane intakes are for race engines, and cannot be used on the street without killing streetable torque...! Don't do it!
Lars
Lars
Dr. Detroit
The Air Gap is good to about 500 horse and even then can be a cork depending on what you are doing....
Jebby
Scott -
Lars
Lars
Build for reliability so you can get some rpm out of it. You don’t get high horsepower in small engines by running rpm under 5500. Main cap studs, main cap bars, and cylinder head studs allow using rpm to make power:
Oil windage is a major power loss. Run a custom, tight-wrapped windage system:
Good heads are absolutely critical. Buy the best flowing heads your wallet can afford:
Then port match the heads and do some careful porting using a flow bench to verify results and consistency:
Run the lightest reciprocating parts you can afford. Top-quality pistons and rods are essential, with some good rings with low drag:
I run custom-ground solid-roller cams with a revised firing order with full roller rockers. This all means very good flow through the engine with resulting power:
I like single plane intakes and “oversized” carbs to top it off. I have found that big headers make big power – don’t believe the crap that you need small-tube headers to make mid-range torque. I run 1-7/8” headers on small blocks with dyno-proven numbers to back it up.
Don’t be afraid to go “big.”
Lars
The following 3 users liked this post by lars:
Cal Custom has been making good quality, polished aluminum accessories for the after market for decades. From a quality standpoint I wouldn't be concerned.
A few years later I found a nice used set of the L-82 covers and after polishing them, replace the M/T's with the L-82 covers. They fit perfectly and looked good! Check the "Bay" occasionally. Used covers clean up and polish pretty easily.
Good luck... GUSTO
