Who sells Vacuum T wiper/headlight
I'm looking for the one that goes from the vacuum tank, to wiper vacuum pod and maybe passenger side headlight vacuum pod. This has the two larger diameter hoses horizontally (5/16 or 19/64 or .303") and vertically has the smaller hose (1/8 or 9/64 or .130"). Doesn't seem anyone sells the replacement and the hose kits do not include it.
Did you try a certain Doctor?
Received 2,878 Likes
Hi D,
I believe the tee you describe isn't the tee used AS you described.
The tee with the 1/8" nipple is the source of the vacuum supply for the operation of the heater/defroster control on the shifter console.
I'm unaware of a current source for the tee in THAT configuration, although there are tees readily available that have the 2 large nipples and 1 small nipple… the larger nipples are at a right angle to each other.
Regards,
Alan
Here's the tee you describe.
It's location is different than in your 70 car.
Regards,
Alan
The aftermarket ones are a little different but work the same. here is one from Corvette Central.
http://www.parts123.com/corvettecent...50g&ukey=18683
