Sidepipe and fuel injection question
Old Apr 10, 2017 | 06:56 PM
Gordonm's Avatar
Gordonm
Default Sidepipe and fuel injection question
Installing a fuel injection system on a forum members car. They want the O2 sensor anywhere from 9 to 3 oclock. No pointing upwards for moisture. There is no way to do this in the collector unless you have it sticking up outside the body which would look silly. The best I can do is about an 8 oclock position. Will this be OK.
Old Apr 10, 2017 | 09:34 PM
'75's Avatar
'75
Gordon, here's a thread with some pics of the O2 sensor in the side pipes.
https://www.corvetteforum.com/forums...o2-sensor.html
Old Apr 10, 2017 | 10:27 PM
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
mine are not properly angled. There was not a really good way to do it so I figured if they foul up every few years then I will deal with it. I have driven mine three seasons and about 10K miles so far and had not problems.
Old Apr 10, 2017 | 10:34 PM
TOM B1's Avatar
TOM B1
My 02 is under the frame rail about 8:00 on the underside of the car as in the link that 75 gave you.
I am running a blower with Enderle fuel injection and a FAST 2.0 ECM
I have a heated sensor and have no problems with moisture so far.
Old Apr 11, 2017 | 05:21 AM
Gordonm's Avatar
Gordonm
Ok. Pretty much what I thought. I am running an EZ efi 2.0 on my Cobra and again had to mount it ata slight downward angle. So far no issues. I will mount this one the same way. Thanks I just wanted confirmation for this.
Old Apr 11, 2017 | 12:05 PM
gdh's Avatar
gdh
A number of Sniper owners have reported issues with the supplied CTS and O2 sensors, in each case once the faulty component was replaced all was good.
Old Apr 11, 2017 | 01:16 PM
SteveG75's Avatar
SteveG75
Same here with my FAST XFI 2.0 setup.
Old Apr 11, 2017 | 02:42 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
that cobra in your avatar looks sweet....I see you have been busy
Old Apr 11, 2017 | 08:57 PM
Gordonm's Avatar
Gordonm
I assume you mean my avatar. Yes it has been a busy few years and the Cobra is awesome.
Old Apr 11, 2017 | 09:45 PM
bobs77vet's Avatar
bobs77vet
yes your avatar.....very sweet, did you build it? whats the drive train/engine?
i am a little less powered these days...
Old Apr 11, 2017 | 09:55 PM
SteveG75's Avatar
SteveG75
Had my car jacked up this evening so snapped a pic of my O2 sensor for you. We actually put the bung in the sidepipe tube so it is a little more downstream of the collector. I have bungs on both sides for tuning but only one installed for the XFI. No issues in over two years. FYI, I am using STS baffles.
Old Apr 11, 2017 | 10:15 PM
Gordonm's Avatar
Gordonm
Steve- That is where I am going to put in. Mine is in the header collector right now. Having it welded in this week.
As for the Cobra power it is just stupid power. It has a 408 ci Ford pushing 540 Hp. In a 2200 lb car I have yet to use full throttle. At half throttle it blows the tires away in the first 3 gears at will. I am running Nitto NT05 with a 200 treadwear so they are soft. And Yes I built it!
Old Apr 11, 2017 | 10:47 PM
htown81vette's Avatar
htown81vette
I had mine installed in the 4 o'clock position (or 8 o'clock position) depending on how you look at it....never had any issues. I had mine installed in the side pipe itself, not the collector.
Old Apr 12, 2017 | 07:56 AM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Nice A Coupe and TD! Methinks I've read your threads on other forums...
Old Apr 12, 2017 | 11:50 PM
lionelhutz's Avatar
lionelhutz
There is no reason the bung has be 90* to the pipe so the sensor points to the middle of the pipe. Put the hole lower down on the pipe and then get a thick bung and cut it to mount at an angle so the sensor sticks out at 9:00 below the frame. Look at the post by wabco40 in the linked thread but put the bung down further and cut at and angle.
To Sidepipe and fuel injection question
