T56 swap with f body hydraulics
In doing a t56 swap(96 f body t56 and hydraulic linkage master/slave); does anyone on the forum (or a vendor) have a solution(eg bracket, plate, custom fab setup) to mount the 96 master cylinder to the 81 corvette firewall?
this is the f body hydraulics:
I did just what you're thinking about. I made a mount from tubing and sheet steel. You can bypass that work with a C10 pickup truck master cylinder that mounts to the firewall at the proper angle. Also, I have seen an adjustable mount to keep the F body master.
Thanks SH-60b, the adjustable mount would be better. Do you know where it could be found?
and how much of the black body part of the slave cylinder need a to be in the driver's cabin?
American Powertrain has something, a little pricey IMO. Maybe there's others.http://americanpowertrain.com/c-6500...acket-kit.html
I used the '85 Chevy truck master cylinder from the local parts house. Works perfect, made of cast iron instead of plastic. Just cut and thread the shaft, add 1 hole in the firewall and your done. No adapters required. I also drilled out the pin on the pedal and used a bolt and a heim joint picked up from the same parts house for about $5.00 to connect to the pedal. Best of all, cheap!
x3 on the '85 pickup master. A remote reservoir from Summit was inexpensive, too.
Did need to cut down the clutch rod and thread a heim joint onto the end to mate with the corvette pedal. Didn't need any adapters, just drilled holes in the firewall and bolted it right up.
Thread:
https://www.corvetteforum.com/forums...my-79-a-4.html
Attachment 48358818
Attachment 48358819
Attachment 48354408
Attachment 48354439
Attachment 48354426
Thread:
Attachment 48358818
Attachment 48358819
Attachment 48354408
Attachment 48354439
Attachment 48354426
I suspect the factory line from the Camaro might just work.
Otherwise, take both cylinders into a speed shop and ask them to sell you the fittings and hose you need. Hopefully you have a good speed shop nearby otherwise figuring out the threads may be difficult.
Here's a mount I made to use the stock fbody master.
Also, the stock line uses a roll pin to attach to the slave cylinder. I think you'll need one of these.
http://www.speedwaymotors.com/LS1-and-LT1-T56-Release-Bearing-to-AN3-Line-Fitting,25017.html
