79 Corvette change from TH350 to BW Supr T10
My 79 TH350 has a bolt-in rear trans frame cross member, whereas a 79 with a 4-speed uses a welded-in cross member. Could I get a cross member from an '80 or '81 that is used for both TH350 and 4-speed and bolt it into my '79 so it would accommodate the T-10 and the 4-speed shifter mount? It looks like it would work, but not sure if I might be missing something. Thanks, John in SW Michigan
That does not solve the problem of installing stock shifter. There is another bracket for shifter (which I have), but no provision to mount it to the 78 TH350 cross member. It looks like it might mount to the 80-81 crossmember.
This is probably what you need...
photo courtesy of Zip Products
http://www.zip-corvette.com/68-79-4-...FdKFswody0sKLA
Or you could just spring for a Hurst Competition Plus! I doubt you would ever regret it.
Good luck... GUSTO
68-79 4-spd Shifter Mounting Bracket
Good luck... GUSTO
Reply as I said, I have that bracket, it just does not mount to the 79 TH350 cross me
MG]photo courtesy of Zip Products
Good luck... GUSTO[/QUOTE]
I have the shifter mount bracket but there is no way to mount it to the 79 TH350 cross member.
