HELP! Broken part in steering column while replacing ignition switch t/t
So I had to replace my turn signal switch on my 1975 corvette tilt/telescopic steering column and while doing so found a broken part not sure what it does two copper tabs into a plastic piece? What is it and how can I get to it or fix it?? I am having trouble removing further pieces how do I even get to the ignition switch? Here are picture:
These fell oit
Plastic is broken what is this?
Without tabs
Tabs loose
These fell oit
Without tabs
Tabs loose
Averystingray75 (05-08-2017)
Averystingray75 (05-09-2017)
Here's a tip that little mark on the steering shaft is the indices for the steering wheel being straight up. Hub of the wheel should have a corresponding mark.
Averystingray75 (05-13-2017)
