Tach drive distributor problem
Corvette America has a good picture of the coupler, side gear, gear button & side gear washer (and all are in the distributor when it jams) and here are their numbers if you want to see what I have tried on two different housings with the same results.....X2601 Tach Drive Gear Assy....
If anybody has an idea please let me know, this is making me crazy
Ooops. Mike beat me to it!
I don't know if you want to move the distributor in to the proper position or not.
If you do that will make the connection much simpler and direct but WON'T solve the problem if the cause is the distributor shaft or gear drive.
I'll post 2 photos and a page from the AIM to give you an idea of the proper clock for the distributor on a Corvette engine.
Regards,
Alan
Notice the position of the spark plug wires too.
You will have some noise from the gears, when the distributor is assembled correctly, it's just how much noise are you experiencing.
Regards,
Alan
Assemble afterwards with bluing, and check the mesh. Should be close to center.
But..
Installing reproduction side and main shaft gears is not as easy as it my appear.
First off... did you check the distributor bushings for play. You do this while running and you use a dwell meter... if the dwell opens when you torque up the engine then you have slop in the upper bushing.
Secondly.. it's rare that we get a set of gears and install them in a distributor and they actually work out of the box... The best way to tell if you'll have any issue is to rotate the distributor in both directions... it should move forward and backward without any binding what so ever... It should be smooth..
How do we accomplish this in house... I have a lathe... so if the gears are binding I can dress of a bit and then re-assemble and test again....
Other issues would be the brass button... If your distributor is correct, installing a brass button would be a mistake because it will cause the gears to bind. Use the teflon button that snapped into place in the side wall and you'd be set.
https://willcoxcorvette.com/corvette...n-62-74-teflon
The only time I use the oylite button in a distributor is when it's a 1969early or older distributor and/or if the side wall is worn out to a point where it needs to be milled and then the oylite button makes up for the wall thickness that I remove on the mill.
The distributor below has a oylite button installed inside it... but it was also machined down so that the button made the original side wall the original size. On your distributor you would have had a hole where the middle of that button is.. but inserting the oylite button will only make the wall too thick. the teflon button should make it the correct size and work considering you buffer the gears to mesh properly.
IMHO,
Willcox
But..
IMHO,
Willcox
There are several things that will cause the cross gears to wear out and the main one is the bushings.
So, if the wall is flat to touch, then I'd go with it. But if the button is elevated to the wall then I'd remove it and install the Teflon button... That's the simple fix.
The gear when installed correctly should rotate freely in both directions.
If the button is elevated and you remove and replace it with Teflon, don't do anything to the cross gear until you do a test fit.
Willcox
