Broken starter bolt - help me source a replacement
Old May 20, 2017 | 07:07 PM
JohnnyQuik's Avatar
JohnnyQuik
Default Broken starter bolt - help me source a replacement
You guys ever start an easy little project that just seems to never end? I've got one of those going on now.
I managed to snap the bolt on the front of the starter that that holds the front starter support bracket. This is the long one that goes through the stater holding the front cover on and holding the main starter body to the rear section. The front end has a threaded section that acts as a stud for the bracket that supports the starter and holds the heat shield and ground wire.
Anyway, does anyone have a source for this bolt or any ideas? Starter is correctly coded for the car (assumed original) and I'd like not to replace it if possible.
This is a '70 LS5 454 BB if that matters.
Broken end:
Last edited by JohnnyQuik; May 20, 2017 at 07:10 PM. Reason: I spell like a second grader
Old May 21, 2017 | 12:17 AM
hipocars1's Avatar
hipocars1
This place probably has it, but I don't know if they sell individual parts for starters. Worth a call.
https://www.precision-pwr.com/
Old May 21, 2017 | 12:51 AM
carriljc's Avatar
carriljc
Default Out of curiousity I looked at the zone
Looks they have multiple starter bolts for 1970 454s.... Knurled and everything from the pictures they show. Take a look.
Broken end:
Old May 21, 2017 | 01:25 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Do you have any independent auto parts store near you(NOT Autozone, Pepboys, etc)? Some of them rebuild starters and alternators themselves.
That's where I found that same bolt when I broke mine
Old May 21, 2017 | 01:49 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Go to any starter rebuild shop. They'll have old GM starters. Those bolts were on every one of them ever made....nothing special.
JIM
Old May 21, 2017 | 06:17 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Or a auto salvage [junkyard]. T
Old May 21, 2017 | 11:29 AM
bigredbrad's Avatar
bigredbrad
From: Lincoln NE Riding and Driving Corvettes since 1967.
replace that worn solenoid fork while you are in there.
bigredbrad
Old May 22, 2017 | 09:43 AM
GUSTO14's Avatar
GUSTO14
JIM
, if we knew where in South Carolina you lived, someone may even be able to recommend a shop to take it to.
Most medium or larger towns will have an independent rebuild shop that specializes in everything electrical on cars, trucks, and even farm machinery. They are a wealth of knowledge and terrific source for hard to find parts such as you're looking for.
I broke an ear off of the original starter on my '73 and went to see my local rebuilder. He gave me a correct nose for my starter and even installed a new bushing it it, all for $15. Needless to say, I send all my friends to him that want to maintain/retain their original equipment.
Good luck... GUSTO
Old May 28, 2017 | 12:30 PM
carriljc's Avatar
carriljc
Just FYI, I broke one of those bolts once and just went to the hardware store and bought some all-thread to get me through until the next time I could completely remove the starter and get it replaced.
To Broken starter bolt - help me source a replacement
