Suspension upgrade Shark bite or ride tech??
Looking to do a resto mod on a 69 c3 Can I get some opinions on what is the best suspension on the market. i have looked at both the ride tech and the shark bite on line. But want to hear from someone that has used either or both.
Also steering upgrade, rack and pinion?
ak l71 (05-22-2017)
I have my ridetech system installed on my 73 and it is a very nice system. All components are top notch. Have not run it yet and it will be another year or two until I am done, but I am not sorry I went with Ridetech despite the cost.
ak l71 (05-24-2017)
It's all I've got at the moment. It's a Dana 44-compatible version of Pier Paolo's 5-link rear. Got the .dwg files from 68VetteModified on vettemod and made all the parts in Solidworks. I'm hoping to get it all fabbed up once I get a tech shop membership from work.
ak l71 (05-22-2017)
Nice! Keep us updated as you make progress! Not much available anymore from what I can find for a 5 link rear suspensions.
Peruse the VanSteel and Ridetech offerings then pick a budget....
Other options are out there but are either technically extreme very difficult like grafting a C4 suspension onto the C3 or swapping out frames that accept C5/6 suspensions which is big $$$$$$$$$.
ak l71 (05-24-2017)
If you have access to a waterjet/laser cutter, a manual or CNC mill, and some welding equipment, then you can fab it up. Other options are to find an old Greenwood/Guldstrand 5-link setup or wait for Van Steel and Detroit Speed's new multi-link C3 suspensions that they're working on. There was a Guldstrand one available in the For Sale section a while back.
https://www.corvetteforum.com/forums...uspension.html
'Dragvette' makes a nice 6-link set up. I know it's old school but VP&B has a dual mount kit that is fully adjustable and it'll make your C3 handle like a go-kart. It is kinda very stiff for street driving. Throw on a set of QA1s double adjustment and you're all set to have fun. T
ak l71 (05-24-2017)
C3 of Year Finalist (track prepared) 2019
Of course, my car works pretty well with near stock factory gymkhana option suspension:
Still running factory springs (shortened in front and longer bolts in rear) and bars, just some Global West upper arms for more caster, poly bushes and Bilstein Sport shocks, and a spacer between strut rod bracket and diff in the rear. And of course an aggressive alignment and some decent tyres. Still road tyres though, not semis (285/40r17 Continental ExtremeContact Sports in this video). Drives nice with reasonable ride quality on the road too.
ak l71 (05-24-2017)
The thing I like about the 'Dragvette' is the wheels travel in a vertical movement versus the arch movement of the stock C3 suspension. With the spring and shock disconnected and the upper and lower hiem rods adjusted correctly the diff stub axel only moves about 1/16 of an inch in and out through the entire travel of the suspension. No need for those I don't know why they are there C-clips inside the diff. T
