SHocks
Old 05-22-2017, 09:50 PM
612kirktho
2nd Gear
612kirktho's Avatar
Default SHocks
Do you have kyb SHocks for a 1990 Chevy Corvette
Old 05-23-2017, 07:15 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
Originally Posted by 612kirktho
...Do you have kyb SHocks for a 1990 Chevy Corvette...
I do not.
Old 05-23-2017, 11:46 AM
MelWff
MelWff's Avatar
Received 1,807 Likes on 1,598 Posts
I have Koni, is this the beginning of a survey?
Old 05-23-2017, 01:43 PM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
Since you asked this question in the C3 Forum, I'll answer for a C3. I installed KYB gas shocks on my '73 back in 1991. I really wanted Bilsteins or Koni's, but couldn't justify the expense to my "accountant" .
Three years later I was able to demonstrate to her via CBA, that the Bilsteins actually made sense. I removed the KYB's with a plan to offer them to a friend that needed some new shocks for free. After removing them I was "shocked" to find that a couple of them had lost their gas already.
The Bilsteins have been on there for 20 years (and about 5k miles) and are still like new. Should'a bought the Bilsteins to begin with. I've also had a set of Bilsteins on my Tacoma for over 90k miles that are still good to go.
Oh, and my C4, well it came with Bilsteins...
Good luck... GUSTO
redcruz1120 (05-23-2017)
Old 05-23-2017, 02:32 PM
redcruz1120
redcruz1120's Avatar
St. Jude Donor '09
Whats the difference besides the monetary difference? I saw them on a site for 499.99. for a set then I saw a vendor on fleabay selling a new set of B6 bilsteins for $380.. Same B6 series
Old 05-23-2017, 06:31 PM
GUSTO14
GUSTO14's Avatar
For 1963 to 1982 Corvette these are the over the counter shocks that Bilstein offers. The B6 is essentially for a stock suspension while the B8 is tuned for lowered suspensions. I believe that the B6 shocks are also often referred to as the Bilstein Heavy Duty, while the B8 is referred to as the Bilstein Sport.
Bilstein B6 Performance dampers are a performance upgrade to OE dampers designed to be paired with the OE factory spring. These dampers offer application specific valve settings with a monotube design to bring out the best handling performance of a vehicle. Each damper is rigorously tested for quality that meets or exceeds OE standards. B6 Performance dampers will provide improved safety and handling performance with the added benefit of world-famous Bilstein quality.
Bilstein B8 Performance Plus dampers are a performance upgrade to OE dampers designed to be paired with aftermarket lowering springs. These dampers offer application specific valve settings with a monotube design to bring out the best handling performance of a vehicle. Each damper is rigorously tested for quality that meets or exceeds OE standards. B8 Performance Plus dampers are the ideal solution for pairing with a lowering spring for improved handling and sportier look with the added benefit of world-famous Bilstein quality.
B6 Performance - Front Shock
Part Number: 24-009461
Old Part Number: B36-0946
Old Part Number: F4-B36-0946-H0
B6 Performance - Rear Shock
Part Number: 24-184649
Old Part Number: B46-0956
Old Part Number: F4-B46-0956-H0
B8 Performance Plus - Front Shock
Part Number: 24-184526
Old Part Number: B36-0222
Old Part Number: F4-B36-0222-H0
B8 Performance Plus - Rear Shock
Part Number: 24-184571
Old Part Number: B46-0232
Old Part Number: F4-B46-0232-H1
Good luck... GUSTO
Old 05-23-2017, 08:46 PM
TWINRAY
TWINRAY's Avatar
I have KYB Gas Adjusts on 5 vehicles. Never a problem:
1969 Corvette, installed 2002
1967 Corvette, 1989
1979 Camaro, 2008
1996 Jeep Cherokee, 2016
1991 Nissan SE-R (struts), 2006
I was going to try Bilstein's on the Cherokee last year but I needed them right away and they weren't available.
Old 05-23-2017, 09:55 PM
7t9l82
7t9l82's Avatar
I have QA1 non adjustables, I wanted bilstiens I ordered springs and shocks from VBP I was in a time crunch and needed them Friday I ordered them on monday.tuesday morning I got a call from VBP the shocks were supposed to be there Tuesday afternoon but they just got word the backorder was extended.knowing I was in a time crunch VBP offered me QA1 shocks at the same price, so I said that would be fine. An hour later I get a call from QA1 and the lady said they would have my shocks direct shipped to me and would be there Friday and don't worry.I went into a little detail about my car said goodbye to the nice lady.
later that afternoon QA1 calls back,I'm thinking this can't be good. One of the engineers says we don't have your shocks on the shelf,oh boy I'm thinking. The engineer says we're going to build you a set this afternoon, and since we are we would like to know some info about your car and what you need.
I was totally blown away that 2 companies went way beyond what they had to and made it right. And sure enough Friday afternoon my shocks arrived and rarely have I been so happy with a product. VBP and QA1 both got a customer for life. Oh and a month later the nice lady at VBP THAT HAS SINCE MOVED BACK TO NORTH CAROLINA called and asked if everything was working as I'd hoped,I said no, the products and service I got from you far exceeded my expectations.
To SHocks
Quick Reply: SHocks
