5 speed Richmond makes terrible noises
Hi,
currently I have a C2 from a friend here to do some work on it.
(Yes this is C3 section, but I think the Richmond-mond is more common here).
He had the car at a shop where they put him the 5 speed Richmond in.
The transmission was used, had 3000mls on it from the previous owner.
Because this shop is 200mls away I have to look for all the minor issues, including this one.
Hereīs the problem: When shifting from one to another gear, there is sometimes a terrible sound when the stick reaches the final position. Clutch still pressed you can change this sound by moving the stick a bit forward and backward.
It sounds like a screaming ball bearing at the end of itīs life time.
Or like if you want to put in reverse gear at high speed, but smoother.
The sound disappears after some seconds, and then you canīt bring it back by playing with the stick. You have to go trough the gears and sometimes it will happen again.
Today I checked all the transmission linkage, have to say there is a hurst shifter assembled to the tranny. I put the pin in the shifter, but everything looked within tolerance, even the bolts to limit the stick travel. No tension between the shifter an tranny levers in any gear.
One thing I noticed when he brought the car was that the clutch was wrong set, the throw out bearing was always pressed. I had to adjust the linkage 1" back to get the right travel.
Now I saw a lot of metal shavings all around the clutch fork, seems it comes out the bellhousing. But inside itīs clean.
Clutch and throwout bearing make no noise, so I doubt the root cause its there.
Because with the clutch pressed I can play with the stick and change the screaming.
Maybe the tranny is toasted? Defective bearing inside? Has someone a similar experience?
St. Jude Donor '05, '09, '15
I have a RG 4+1 in my 65. It doesn't make any noises as you describe. Seems like you are saying it makes the noise when the clutch pedal is depressed. I would agree possible bell-housing alignment off and/or trashed pilot bearing. Especially if the installer used a needle bearing type pilot bearing.
Tom
Tom
Hi,
yes, all forward gears when clutch is depressed.
Trashed pilot bearing would also explain the metal shavings around the clutch fork.
Hm yes, could explain why the noise disappears after some seconds with the clutch depressed. Should happen when the Enginespeed drops to the same speed of the input shaft. Iīll try to rev the engine next time and hear whats happening, thanks
do you perhaps have a Centerforce clutch? My ROD 6 speed also makes a bit of a racket at idle. I have indexed my bellhousing, use a pilot "bushing"(not bearing), and checked everything I can think of several times. From reading some other sites I may cut those weights off my centerforce dual friction.... rumor has it they may make a racket.
Received 3,043 Likes
St. Jude Donor '05
wieghts give it additional clamping force, leave them on.
Sounds like the Throwout bearing to Me .
But he said "Clutch still pressed you can change this sound by moving the stick a bit forward and backward." The bearing is isolated from the input shaft by the retainer so this made me think it's the relationship of the input shaft center-line to the crankshaft center-line.
He really needs to take it apart and visually check things out, and also verify bellhousing run out.
Thanks for all the input.
Before I drive it the next time Iīll remove the dustcover from the bellhousing and see if there are also metalshavings inside. If so the tranny has to be removed anyway, no matter if the pilot or throwout bearing.
Maybe too obvious, but did they fill it with the proper fluid?
Had the same thing happen to My 84 Z-28 back in the day. Started squealing on Monday , couldn't fix it till the weekend had to drive it to work. By Friday night I needed a throwout fork , t-bearing , p-plate , and Trans input retainer sleeve. The spinning T-out bearing wore thru the sleeve , and made all kinds of noise that changed with in gear or not.
Ok, after another test drive I can describe it more detailed:
It happens when the previous gear has been pulled out, and you try to put in the next one. Then when the input shaft has to adapt to the new speed.
At this tranny I can hear the reving up or down of the input shaft always, itīs not to loud but a bit unusual in my opinion. Also it makes a rattling sound when car parked and in idle that dissapears when the clutch is depressed. Sounds like my old muncie with 180.000mls on it. (But the muncie had no other issues)
So I guess its the input bearing, because when you shift you put axial load onto it right?
And with pulling the stick harder or softer I can change the sound.
And I believe thatīs what it doesnīt like when itīs worn out.
In this relation it would be interesting to know it the input bearing takes both, the push and pull forces when shifting the forks forward or backward. Does anybody know? If it takes only one direction then it should only appear when shifting the stick forward or backward.
Btw: had already removed the dust cover of the bell housing, found no metal shavings inside. From all the behaviour I can also exclude the throwout bearing now.
