1976 Corvette - Engine Mis-fire around 3,000 RPM
We have a 1976 Corvette that has a mis that starts around 3,000 RPM. We have gone through the electrical - new plugs, wires, coil, distributor, etc. Installed a new Edelbrock carburetor and aluminum intake manifold. Compression test shows consistent readings for all cylinders and an inspection showed no broken valve springs. There were 2 spark plugs that looked like they were not burning as clean as the other cylinders, but other than that everything checked out. Timing was adjusted as well.
Could a bad catalytic converter cause the issue? I don't know if the converter is bad but thought it might be the culprit.
Any ideas on the possible cause are greatly appreciated.
thank you!
thank you!
can you disconnect the cat and test it?
the problem existed before you replaced all those parts?
the distributor is a new HEI unit with no cracks in the cap or rotor?
you did a resistance test on the plug wires?
what plugs are you using, make and number?
what plug gap are you using?
Did you replace the control module?
I will assume all of the electrical components that were replaced were done correctly, and that nothing changed after they were replaced. If that's the case, then you are probably correct in looking at the catalytic convertor next. If its the original convertor, its likely to be plugged. Those early design convertors were not as efficient as modern ones at the best of times, and were more susceptible to becoming plugged. And I would say your symptoms are consistent with a plugged convertor.
I will look into your suggestions when I get some time over the weekend. The issue started before the new parts were installed. We suspected electrical so we started with the new HEI distributor, Accel coil,wires, plugs, etc with no change. Pulgs are AC Delco - I will confirm the model and gap this weekend.
The car operates just fine under 3,000 RPM, idles smooth, starts easy.
It has been awhile but we were able to swap out the converter but we still have the mis-fire that starts around 3,000 rpm. Could this be a bad cam issue? Is there an easy way to test this?
thanks,
Chad
thanks,
Chad
A worn exhaust cam lobe can cause a popping noise thru the carb. Aside from that, a fast way to check for a worn cam shaft is to remove both valve covers and check the valves for travel, by rotating the engine. A couple valves may not open as far as the rest indicating a worn camshaft lobe(s). If you want to get really technical about this then get a dial indicator and place it on the edge of the valve retainer and measure the travel by rotating engine, do this for each valve. Your not really looking for an exact number here just a variance between the rest of the valves. Mind you intake and exhaust valve lifts are not the same, so take that into consideration when you measure.
